Question about Seche UltraV UV Lamp (Seche)
How do i put the batteries in - Seche UltraV UV Lamp (Seche)
Dead Battery?
Take out the batteries. Also take out the backup battery. It is a button battery beneath the screw in the battery compartment. Check the button battery volts with a multi-meter. After 5 minutes put the button battery back in and then the fresh batteries. It might work now. Alternatively take out a battery, then hold the clear button and put the battery back in. Then try to turn on. If it still does not work take out a battery press the del button and put the battery back in.
Feb 06, 2014 | Texas Instruments TI-83 Plus Calculator
Battery
Might be the camera's battery terminals, not the battery itself. Take a qtip and some isopropyl aclohol and clean the terminals in the battery well of camera.
Jul 23, 2013 | Nikon D3000 Digital Camera
Need "how to" instructions on changing the battery
Remove the cables, look for any bolts holding the battery there, there should be at least 2, loose them, pull out the battery, put the new one in, put the bolts on again and tighten them properly (not too hard). put on the cables again. Be sure to put the right cable on the right pole! if you put it on the wrong pole you will have a surprising, yet very nice to watch rain of sparks. some newer cars have the battery inside a box like thing, if you cant see the battery just by popping the hood, it should be inside a somewhat rectangular box. Good luck :)
Aug 11, 2012 | 2006 Jeep Commander
I have 2002 VW Jetta and the dashboard gauges are not working. I tried to start my car and it stalled 3 times then finally started. The battery light was lit up when it stalled. What is the problem?
OKmheres what i did and it worked- 1-take battery out and charge fully 2-Put battery back in car but put positive battery cable on first-dont tighten up yet 3-put negative battery cable on battery dont tighten yet 4-wait 2-minutes 5-take positive cable end off,ho;d in hand 5-take negative cable end off battery ,hold this in other hand 6-now hold both cable end together for 30-seconds -now put battery cable back on battery-make sure you put Positive cable back on First,then negative cable next-tighten both up-Now go see if dash lights are on-then it should start!! if not,repeat cable procedure
Apr 02, 2011 | 2002 Volkswagen Jetta TDI
When I put my battery back into my camera after charging it. The camera will still not turn on. Why ?
Check the position of the batteries. Some camera require the batteries to put in (+)(+) positive-positive position if we see from above. Some other require the batteries to put in (+)(-) or (-)(+) or (-)(-).
Make sure you have put in the batteries in the right place.
Sometimes, unchargeable batteries will stay longer than chargeable batteries, You can try to insert that kind of batteries.
If useful, RATE please.
Jan 18, 2011 | Casio Exilim EX-Z77 Digital Camera
I put a new battery in 2 times and the battry is
Some feature on your opener must have a switch that is stick in the closed (on) position. Possibly, you put a near dead battery into the device? Please check with a volt meter.
You could check the device with a volt/ohm meter in the circuit ... put the meter between the + post of the battery and the + contact of the device. Put a wire on the - battery and the - device to complete the circuit ... if you are using power, there should be some amp reading on the meter.
May 31, 2010 | Lightwave Tech (200.0074)
Phone was working, when the battery was very low, i switched it off to get the sim out of it and when I put back the battery to switch it on.. it doesnt want to start. Its been dead ever since, any chances...
Hi!... I think your battery is very drained. Try to "shock" the battery first. If you have a DC supply at home, set the supply at 6-10V then Put the negative terminal wire to the negative terminal of the battery and in a snap put the Positive wire to the Positive Terminal of the Battery. Then put your battery back to your phone and charge it. It will probably be ok.
Oct 01, 2009 | Nokia 3110 Cellular Phone
How do you put the batteries in the Vivicam 5022 digital camera???? Which way do they go????
The batteries are put in so that the first battery positive end is down, the negative down second, and the positive end down last.
After you've put in the batteries (-+-).
Sep 01, 2009 | Cameras
Can't get the battery connected after putting on
Try connecting the battery before you put on the cover.
Jul 11, 2009 | 2004 Chevrolet Colorado
Toro 20045 Mower will not start. Battery is putting out 13 volts and all I get is a slight grown.
While the battery may be putting out 13 volts...it may not be putting out enough amps to turn the engine over...try charging/replacing the battery.
Apr 19, 2009 | Garden
Seche UltraV UV Lamp (Seche) Logo
41 people viewed this question
Top Seche Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Seche Health and Beauty Expert? Answer questions, earn points and help others
