NEED HELP WITH SHARP AL-1010
MY SHARP AL-1010 COPIER KEEPS DISPLAYING "L6" . NEED SOLUTION TO THIS PROBLEM.
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; According our service manual 'L6" sub code 10 is laser drive, motor, problem, replace laser unit . the laser unit item# is DUNTK0013QSZZ, it located at left hand side of the toner cartridge inside the machine.
Posted on Jan 24, 2009
We have a error code L 6 that keeps popping up. What is it?
L6 is usually a motor issue but need to know which L6--
Mar 20, 2014 | Sharp AL-1000 Copier
Red LED's on Sharp AL 1010 shaped like bowling pins
This is your out of toner indicator. I describe them as a stack of 6 dots. In any case you will need to buy a new toner cartridge or have your current cartridge refilled.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Sharp AL-1010 Copier
It is a Sharp al 1000 with error message L6 which means Polygon mirror motor not up to speed? How is this fixed and what cost?
Since the polygon motor is part of the laser unit, it would cost about $200 plus labor to replace it
Jun 14, 2010 | Sharp AL-1000 Copier
Sharp AR 207 displaying L6-10
HI for L6-10 you must change the polygon motor and if you are unlucky may change all the laser unit but usually with the polygon motor it is ok
Mar 22, 2010 | Sharp AR-207 Copier
LASER UNIT FOR SHARP AL-1010
GO ON LINE SHARP AL-1010 LASER COPIER SCHEMATICS.
OR THE LOCAL LIBRARY TO INDUSTRAIL COMMITION STANDARD COMMITION, THE BRANCH OF THE COVERMENT THAT REGULATES THAT PRODUCT SHOULD HAVE THE SCHEMATICS OF THE COPIER OF A DEALER OF THE EQUIPMENT SHOULD ALSO HAVE THEM ON MICROFISH, OR KNOW WHERE TO LOCATE SUCH THINGS, OLD TYPEWRITER REPAIR SHOPS MAY HAVE IDEAS WHERE TO LOCATE THAT DOCUMENTS AT
ROD
Feb 09, 2009 | Office Equipment & Supplies
STAUS INDICATOR SHOWS "L-6" ON SHARP AL-1010
Dear sir; The L-6 error code it means "laser drive, motor", It can be reset, the procedure as follow;
1, press "clear", "exposure mode", "clear", "exposure" those keys.then machine go dead.
2, enter 14, then press print.follow the direction willtake car the problem.
If you need more help just let me know I'm always around, or generously give me good rating. thank you,
HAVE A MERRY CHRISTMAS !!!
Dec 23, 2008 | Sharp AL 1215 Black and White Copier
Sharp AL 1010
Hi, to reset drum light follow this sequence: press cancel, exposure, cancel, exposure. Display goes blank, enter 24, print, 07 print, cancel cancel. Cheers
Andy
Jan 25, 2008 | Sharp AL 1215 Black and White Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
194 people viewed this question
jasbo
jasbo
