Ricoh aficio sp c231 sf parts cods fuser assembly
4 Suggested Answers
  • 903 Answers
SOURCE: ricoh aficio sp 3200sf fuser door open error
There is a black sensor that detects when the fuser door is closed, and an actuator that the sensor either sees or doesn't see. If this sensor is dirty, it might not be seeing the actuator. It could also be broken or knocked out of place.
Locate the actuator on the side door (a small metal or plastic tab that sticks out from the door) and find the corresponding sensor. Make sure the sensor is in place and not broken or moved, and make sure it's connector is well-seated. If you have a can of compressed air, blow it into the sensor to clear away any dust or dirt.
Posted on Jun 19, 2010
micromatikal
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
dtp_prajapat
SOURCE: Model No. In Ricoh Aficio
Model No. In Ricoh Aficio sp 1100sf
Error Massage displayed (Printer error fuser temp.
Posted on May 17, 2012
Part of printed copy is washed out ricoh aficio sp c210sf
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
Oct 02, 2014 | Ricoh Aficio SP-C210SF Printer
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Jan 02, 2013 | Ricoh Corp Aficio SP C231N Laser Printer
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Ricoh aficio sp-1100 sf toner chip reset problem
WE HAVE RICOH PRINTER SP 1100SF & REPLACED CARTRIDGE WITH NEW RECYCLED BLACK TONNER CARTRIDGE FROM POWER POINT, BUT UNABLE TO PRINT AS CHIP GIVEN IS NOT ACCEPTED BY PRINTER. TRIED 3 DIFFERENT CHIPS STILL PROBLEM PERSISTS. WHAT MAY BE THE RESEASON AND SOLUTION
Nov 30, 2010 | Ricoh Aficio SP-C210SF Printer
Fuser replacement for my ricoh
Generally it is recommended to have a tech do this. the reason being that if you accidently touch the fuser wire the oil from fingers can fritx it. There is a counter to reset but all the playing around to do this ( with a warranty if it goes wrong) is better to have it done by the tech.
Please rate our help to keep the FREE service online ++++
Thank you for using FIXYA.COM
Sep 01, 2009 | Ricoh Aficio SP-C210SF Printer
Ricoh Aficio SP C411DN printouts can be rubbed off of paper or lables
Fuser pressure roller is worn. Fuser is sold as part of the "maintenance kit"
Apr 16, 2009 | Ricoh Aficio SP C411DN Laser Printer
Part Number for RICOH Aficio MP C3000 Fuser Unit
Part number is: B237 4053 (North America)
B237 4054 (Europe)
I Expect this will be very expensive as it is not designed to be replaced as an entire assembly, but rather repaired as needed.
Feb 23, 2009 | Ricoh Aficio AP2000 Laser Printer
Fuser Assembly Unit for RICOH Aficio MP 6500 Printer
This part number B2484582 is modified.
The new part number for the fusing unit is B2484583.
Yes, you can find it from a Ricoh Supplier.
Good luck and please rate me, thanks.
Jul 06, 2008 | Ricoh Aficio AP2000 Laser Printer
37 people viewed this question
jasbo
jasbo
