Question about Pioneer VSX-S500 MULTI-CHANNEL RECEIVER
Pioneer vsx-s500 won't turn on - Pioneer VSX-S500 MULTI-CHANNEL RECEIVER
5 Suggested Answers
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
Posted on Aug 02, 2009
  • 4 Answers
SOURCE: Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Posted on Aug 12, 2009
  • 14 Answers
SOURCE: Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Posted on Apr 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: My stereo pioneer VSX-517-K stopped
"Had it checked out'... what did they conclude?
Painful heat is very bad.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Aug 17, 2011
VSX-D308 Pioneer Receiver
You most likely have a shorted amp IC.
May 04, 2013 | Audio Players & Recorders
Brand newpioneer vsx 822k sub-woofer won't work
Make sure front speakers are set to small. If you set them to large, the subwoofer output in turned off.
Mar 18, 2013 | Pioneer Audio Players & Recorders
Pioneer VSX-40 won't power on
check the fuse or ic regulator
Feb 26, 2013 | Pioneer VSX-D307 Receiver
Pioneer receiver won't turn on
have you look to see if the fuse has blown that usually the problem, just take the cover off and we'll see the ormore then one fuse check them all.
Jun 24, 2012 | Pioneer VSX-818V-K Receiver
I've just bought the pioneer vsx 921 receiver with
The company's advertisement says it all. The company has mentioned the receiver as "Industry's First AV Receiver Designed for iPad". So it cannot compared with TV.
May 05, 2012 | Pioneer Audio Players & Recorders
Won't power up at all
If there is no power on on the primary side of the transformer look for a open fuse.
Apr 04, 2012 | Pioneer VSX-818V-K Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Need a pioneer vsx 305 remote
Search eBay for "Pioneer vsx-305 remote" and check the 'Include description' box. Many available.
Aug 31, 2011 | Pioneer VSX-305 Receiver
I have a Pioneer VSX-D412 reciever, and connot get my b channel to work. Only my A channel works, and I'd like to get both or all 5.1 working. And no I don't have the manual for the system.
In case you didn't see this on the other post, it is not the function of unpaid Fixya Experts to do the web searches for or read the manuals to those who can do it themselves. Most questions submitted to us would find answers immediately if they were typed directly into a search engine.
If you don't have the manual I recommend you get it. There may be other questions. A search for "Pioneer VSX-D412 manual" finds it.
What sources fail. How is it with test tones? have you isolated (swapped) the speakers?
Here is the service manual if you should ever need it. http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-D412_RRV2727.pdf
Aug 04, 2011 | Pioneer VSX-D412 Receiver
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
Pioneer VSX-S500 MULTI-CHANNEL RECEIVER Logo
113 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
