Question about Delta Force: Black Hawk Down for Windows
Wrong cd inserted - Delta Force: Black Hawk Down for Windows
Why does it reads "please insert the correct MAP CD"
I experience a similar thing, however I realized that I had the wrong CD Rom. Pls ensure that you have the correct cd for you locality, hope this helps.
Apr 24, 2014 | Eclipse AVN5500 Car DVD Player
Placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
I cant get my cd out. i inserted it the wrong way how do i solve this cause it say's No CD and wont let me take out my CD
The Cd would have locked into the mechanism as it was inserted wrongly . This will not allow it come back as the surface pressure to push it back will not be applied. so it will be necessary to remove the mechanism and the carriage assembly to assist in bringing out the CD.
Do not use excess pressure but it can be tried with a little bit of assistance while ejecting. Use a non metallic probe to push lightly.
Feb 05, 2011 | Computers & Internet
Does not recognize disk
Either:
* the disk you're inserting is not "empty" -- try it on a different computer;
* you should try a different manufacturer of "blank" disks;
* you need to upgrade the "firmware" inside your CD-writer, to recognize more brands of "blank" media;
* the CD-reader is malfunctioning -- when you "cancel" the burn-attempt, and insert a commercially-produced program CD or commercially-produced audio CD, can those disks be properly read?
* you have two CD/DVD devices in your computer, and you're inserting the "blank" disk into the "wrong" device.
Jul 18, 2010 | Yamaha CRW 2200E CD-RW Burner
How to remove covers to retrieve cd wrongly inserted
please what the make and model of the device that Cd was wrongly inserted into?
I look forward to your reply.
Bye for now.
Mar 26, 2010 | Canon Office Equipment & Supplies
Playstation 2 slim console, doesn't spin so it doesn't read discs
The following could be the problem;
1. It could be that you inserted a wrong format of the CD.E.g Inserting a PAL cd into an NTSC console.
2.The CD is jammed and may need to be re-booted.
3. The CD you are inserting is a bad disc.
Best regards
Jan 05, 2010 | Sony PlayStation 2 Slimline Console
Asked for format disk when insert CD with existing data on CD drive
There is a small possibility that your lens on the CD Player is dirty. Use a normal CD Lens Cleaner, with no solutions, and run it through 2-3 times to clean the lens. Then re-try the CD in question. If you still have problems, it may be the CD you are using, that may have been formatted wrong when initially created....
Sep 20, 2008 | Acer Aspire 3680 Laptop
Delta Force: Black Hawk Down for Windows Logo
130 people viewed this question
Top Delta Video Game Consoles & Games Experts
James Wishart
Are you a Delta Video Game Console and Game Expert? Answer questions, earn points and help others
