Question about RCA RT2380 System
RCA RT2390 Surround Sound won't work
My Rca Surround sound system was working well with my old analog tv, but whe I hooked it up to my Samsung Flat Screen HD TV it will not work. It will not even work on the radio mode. What could be the problem?
  • I know all Jan 24, 2009
    I have a samsug flatsceen and can not get the suround to work on the tv for cable...
4 Suggested Answers
SOURCE: surround help
on my sound system my left and right speakers r blinking
Posted on Aug 01, 2008
ButtFuzz
  • 463 Answers
SOURCE: How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Posted on Feb 27, 2009
SOURCE: rca rt2390 lost remote 5 years later lost
I found somewhere called newremotecontrol.com they have the remote for less then $20 bucks ... I lost my remote 3 years ago
Posted on Apr 19, 2009
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
We want to hoop surround sound to the tv and can't get it to work. Help???
If the TV has a Optical Digital Audio you can hook this to your surround sound reciver. If not you have no way to get true surround sound out off your set, just analog stereo from the RCA jacks.
Oct 09, 2010 | LG Televison & Video
How do you hook up rca surround sound system to rca tv for sound
I can not figure out how to wire my 46" lcd rca tv to my rca surround sound.
May 21, 2010 | RCA L32HD31 32 in. LCD HDTV
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Surround sound dvd player/tv channels are fuzzy
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Jun 24, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Surround help
Hmm. let me see if I get U correctly. you use u'r theater system with a TV and the audio is fed via optical or U have DVD player that you can feed the audio via optical or coax. I think it is the later, if it is U could be having trouble with sound decoding setting of the DVD player itself. It's like mpeg out or PCM out instead of full DTS or 5.1 dolby digital decoding. If this is the case just use u'r dvd remote and check the audio play back settings. If this does not solve u'r problem, pls state u'r set up briefly, so tht I can understand the type of connection u use. Happy troubleshooting Rifaa
Jun 11, 2007 | RCA RT2390 System
RCA RT2380 System Logo
1,133 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
