Question about HP Pavilion dv1000 Notebook
HP dv1000 Laptop Locks Up
My old HP dv1000 Laptop has decided to start locking up for no apparent reason. The screen will freeze and laptop is not responsive mouse or keyboard input. The only option is to pull the plug and restart. I thought it might be heat related, but it sometimes happens right after boot up so the heat hasn't even built up to any level at that point. On occasion, it will do the same thing following any slight movement of the laptop. Bad connection somewhere in the motherboard maybe? Open to all suggestions/ideas.
Thanks,
Ron
  • 2 more comments
  • usaf_463 Jan 24, 2009
    RE: Theadamray
    Yes, I can power off with the power button.
    RE: TAT4U
    I've just finished running defrag. I was setting up to do a full disk scan for bad sectors when it locked up again. I've rebooted following the lockup and it is once again locked up at the login screen.
  • usaf_463 Jan 25, 2009
    TAT4U
    I worked on this late last night and after several attempts, finally got a full scan with the XP built in disk scan. I also removed and reinstalled the HD just make sure the contacts were all seated properly. I removed both RAM modules and inserted them in opposite slots for the same reason. This seemed to do the trick as it ran ffor hours with no problems. However, I found that my AV client could not register it's upgrades and java would lockup when trying to upgrade. I uninstalled and reinstalled both to no avail.
    Following that, I decided to reinstall XP using the repair option. It worked, but now the lockup problem has returned.
    Overall, I'm not losing any sleep over this issue as this is only a backup laptop. When the problem first arose, I convinced my wife I needed a new replacement. Although I want to keep XP on it, I also want to use it to test Windows 7 Beta which I just downloaded.
    FYI - mydrive.ch is a site with a free online storage capability for up to 1 GB of any kind of files. I use it all the time for various files.
    Thx,
    Ron
    TAT4U
    Thanks for the offer. That program might be just what I need. Also that recovery program would be great. My laptop is an HP doesn't have the usual recovery partition that Dell uses, so I can't restore to like new condition easily. It's always a problem doing a complete reinstall of the OS because you have to also find and reinstall all drivers and native programs like CD burners.
    Here's a good contact email address: ronsweb@cableone.net. Be sure to put a good recognizable subject line in case your message gets caught in my spam filter.
    Thx
    Ron
  • theadamray May 11, 2010
    When it locks up does it power off if you hold down the power key for 5+ seconds?
  • 520 Answers
It maybe bad sectors on hd but first Id defrag disk see if any improvement
Posted on Jan 24, 2009
  • tat4u
    tat4u Jan 24, 2009
    have you tried removing and replacing ram(mem)
    this is worth a try which takes minutes..because I'm pretty certain its bad sectors and you'll have to repair the hd with separate software.
    paragon hd recovery(repairs faulty hd,bad sectors,drives which wont format for any other software)
    ;...is the best program Ive used for this,and I've used many,spotmau is a great all rounder but I have had drives so damaged that even spotmau cant do but paragon has never failed me.one particular drive never leaves me ...I ended up wiping disk entirely fixed bad sectors and formatted with paragon and then when it came to installing os where it asks where to install and then formats I selected make no changes and install to existing drive and that did it (windows by default always executes a format before any install)if you cant find any programs that allows you to perform these duties I will see if I can find link for you...
    I have all programs which I ever mention just that cant send cos attachment only allows 10mb and most zipped programs are a little bit more than 10 meg
  • tat4u
    tat4u Jan 25, 2009
    your hd may still have bad sectors on ..you can intall os on drive with bad sectors ;but after a while these bad sectors become worse until os is unavailable and drive wont format using regular methods.your drive seems it may not have too many bad sectors but if want send me email and I'll give you a link for spotmau which will repair bad sectors and a whole lot more.you could search for a copy on net but it will be trial version so if you want to unlock the power of the software you have to buy it.my link is the full software which I'll also send the key...also I can send a recovery program for when you have pc running sweet.so as in future if any os probs you just press f11 at boot and it restore pc to previous state (before probs)in a matter of minutes
Hp laptop start screen zoomed in
Ctrl - should allow you to zoom out.
Nov 27, 2013 | HP Pavilion dv1000 Notebook
HP DV1000 won't run normal after a forced shutdown
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement HP Pavilion DV1000 AC Adapter 65Watt 18.5V 3.5A
Oct 28, 2012 | HP Pavilion dv1000 Notebook
Hp laptop windows 7. touchpad locks for no reason. how do i unlock it?
Search for the button for PAD LOCK, of press Fn + some other buton to unlock...
and next time write pc model.
Jul 09, 2012 | HP Computers & Internet
Once turned on, cant login cuz keyboard n mouse freeze...
THAT MEAN YOUR LAPTOP HAS VIRUS SO YOU NEED TO REFORMAT YOUR LAPTOP SO IT WILL HAVE NEW LIFE THE VIRUS HAS DAMAGE THE OPERATING SYSTEM TOO MUCH SO YOU NEED TO RE-INSTALL THE OPERATING SYSTEM BEFOR THE VIRUS DAMAGE SOME HARDWARE TOO.
Nov 20, 2008 | HP Pavilion dv1000 Notebook
Hp dv1000 media controls
Hey Gigantegenov!
Seems like the program that controls your special keys (volume control) causes your computer to freeze!
I would recommend reinstalling the drivers/application for it. Try this download and let me know what happened: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-31502-1&lc=en&dlc=en&cc=us&lang=en&os=228&product=435618
Cheers!
Nov 11, 2008 | HP Pavilion dv1000 Notebook
Safe mode
Hi i am really sorry for the thiung happened, i suggest to change thge power options in Control Pannel so that the System will not go to sleep mode when you close the LID. Change the power options the Never,
If you are confused with this please reply to me i will give you instructions further.
For clear idea please reffer to this document to resolve the issue, every thing is explained in detail
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00845808&dlc=en&lc=en&jumpid=reg_R1002_USEN
All the Best
Kiran
Jul 12, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000
I found out how to fix the no sound problem on The HP Pavilion DV1000 Look under Dv1310 thats the model number the driver your looking for is SP30262.exe
Feb 27, 2008 | HP Pavilion dv1000 Notebook
Hp pavilion dv1000 notebook Pc will not start
mother board filure willbe the reason . consult a n authorized service technician
Dec 07, 2007 | HP Pavilion dv1000 Notebook
Laptop Freez up only a few minutes after I turn it on.
You possibly have to many programs starting up when you turn on computer,try going into msconfig and turning off things that you don't need to start up.
Apr 26, 2007 | HP Compaq Business NX9110 Notebook
HP Pavilion dv1000 Notebook Logo
268 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
