Question about Neff Dishwashers
Neff S4840 dishwasher will not drain
Neff S4840 dishwater does not drain dirty water after cycle. How do I get dishwasher cover off to see if any food blockage.
  • 883 Answers
SOURCE: Neff S5555 - empties water but stuck in draining mode.
if this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Posted on May 26, 2007
  • 4 Answers
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Posted on Mar 14, 2008
  • 7 Answers
SOURCE: Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Posted on Oct 09, 2008
  • 120 Answers
SOURCE: water wont fill
first of all, i'm gonna guess that the water supply under the sink is turned on.
the water you hear is the left over water from a previous cycle. there is always some left in the hoses after it drains, just like your washer.
this is 1 of 2 things. either your float is stuck in the up position or your water inlet valve is malfunctioning. the float is the quick and easy fix. the float is somewhere inside your dishwasher. it tells the water to stop coming in when it reaches a certain height, just like your toilet. it could look like anything, but most likely a cone or a little hat. just grab it and try to move it up and down. it should slide freely. it was probably stuck up and your handling will have solved the problem. we hope.
if the float was ok, the inlet valve needs checked or replaced. it is under the machine and has the water supply line hooked up to it. good luck
Posted on Nov 02, 2009
clrvuedoc
  • 175 Answers
SOURCE: glasses int he top rack of my kitchenaid
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Posted on Mar 01, 2011
Testimonial: "thanks very much i'll try that. turns out the junk trap was clogged had to disssassemble the rotor to get at at it"
Water not draining away. tap icon displayed
http://www.neff-eshop.com/eshop(bD1lbiZjPTAwOQ==)/neff/gb/prodp.htm?prod=S5555X0GB%2f94&ESHOPTYPE=S
go to link, look at page 4, using a tx20 driver remove the pump cover indicated by number 0462 on diagram, check for obstruction, may be a piece of glass etc so go careful, remove any debris and check the impellor turns ok. The unit will not drain without this cover refitted but you can check impellor is rotating whilst it is off. Check all outlet hoses, particularly the spigot connection under the sink if this is how it is fitted, Good luck
Jul 06, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
My neff 3 in 1 auto dishwater. got up this morning and there was water in bottom of it,as if the water never drained out
Reset, clean drain and try again. sometimes there is small blockage (Slipped Pipes Bit like slipped Arteries) preventing full drainage, it can also happen when drains are frozen
Feb 24, 2010 | Dishwashers
Neff dishwasher water not been pumped out
ck drain for kink in hose . and if connected to disposal ck the hose at that point . must be clear. ck for bone/glass / toothpick/ ect / m m
Dec 17, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
My neff dishwasher will not fill will water and will not complete program - cleaned and checked filters to the best of my knowledge - can you help?
i if it doesnt fill with water check it is actually draining is there water in the tub etc?if it cant drain it wont fill or complete the cycles,this is usually a blockage in the pump the handbook tells you how to deal with this problem.
Jul 29, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
May 26, 2007 | Neff 24 in. S5555X0GB Built-in Dishwasher
Dishwashers Logo
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
