Question about Indesit Washing Machines
I have code f06 on my IWD71250 washing machine
5 Suggested Answers
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
canbruce75
  • 1776 Answers
SOURCE: What does the F06 code mean? My machine appears
The F06 code usually indicates a motor related problem. Some potential causes are loose/corroded connections of the wiring harness between the motor and the motor control unit (MCU) or between the motor control unit (MCU) and the central control unit (CCU). Sometimes this problem can be fixed by removing and reseating the electrical connections at these locations, but unfortunately I believe that your motor is shot. I say that because one of the ways to test the motor is to remove belt and turn pulley by hand. It should rotate freely. Then, run motor without belt (which you said you did). If the motor will run without the belt, but won't run under load (with the belt on), then this is a sign that the motor is bad. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Aug 24, 2009
SOURCE: i need to know what f06 error code is on a
On my whirpool top loader a magnet fell off from a drum so the microswitch can not count revolutions of a motor and an f 06 error went on
Posted on Nov 03, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I have a kenmore he3t quiet pak4 front load washer. First of dhl code. I ordered a new door lock and put that in. Then I got a f06 code. Put back in old lock and still only get f06 code. The other...
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its either a faulty MCU, or faulty drive motor.
Nov 03, 2014 | Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
411 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Chris Hall
Chris Hall
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
