Question about Compaq Presario Notebook
Compaq Presario 2800 boot error
Ok, so I wanted to add more memory to my laptop. I had an old laptop lying around, so before I went to buy another memory I thought I would switch out one of my sodimms with the one in the other laptop. So I did, and I pressed F1 to save the changes, everything was going well until I got Windows Boot Manager screen, saying that:
Windows encountered a problem communicating with a device connected to your computer.
This error can be caused by unplugging a removable storage device such as an external usb drive while the device is in use, or by faulty hardware such as a hard drive or cd-rom drive that is failing. make sure any removable storage is properly connected and then restart your computer.
If you continue to receive this error message, contact the hardware manufacturer.
File: Windowssystem32winload.exe
Status: 0xc00000e9
Info: An unexpected I/O error has occurred.
So I press enter and I get a screen where I can choose the operating system. All I have is Vista so I press enter and it sends me back to the error screen.
So I say ''Snap!'' and I turn everything off and switch back to the old memory. Then I press F1 again and everything happens the same again!! Please help me!!
  • 3 more comments
  • stepht319 Jan 24, 2009
    no this is not during an install. i just put the regular memory back in and pressed f1 to save changes. i'm not installing anything, just trying to start up my computer
    nothing happens when I press F8
  • stepht319 Jan 26, 2009
    I don't think this problem had anything to do with the memory after all.  I finally fixed it.  But I had to reinstall the OS.  I believe it was having this problem before I even shut down the computer because it couldn't find another file it needed to install a program.  Then the computer froze on me and I became impatient.  This is where I believe I ruined it.  Because I pulled out the battery.  So, I may be wrong but I thought that maybe I just ruined the file.  I reinstalled the system and everything has been fine since.  I upgraded the memory without any problems.  Thanks for trying! (And even though I pressed F8 repeatedly, nothing happened)
    I would have if I had thought at the time that it was important.  But I was at a loss, I'll know next time.
  • Stephen Wilkins
    Stephen Wilkins May 11, 2010
    is this during install? have you tried F8 system restore or fix startup problem? make sure if you have any card readers theat there is no cards in them... including Pcmcia
  • 186 Answers
Tried F8rapair your computer and startup repair and system restore...
Posted on Jan 24, 2009
  • 1 more comment
  • Stephen Wilkins
    Stephen Wilkins Jan 26, 2009
    you have to tap it repetitively until you get the menu and as soon as you turn on your computer and the bios screen goes away...
  • Stephen Wilkins
    these are all important things when you are having an error ....... you should have posted this the first time...
  • Stephen Wilkins
    no worries...
My compaq notebook presario cq50 210us is frozen on a black screen
Try the laptop on an external monitor, if it works ok on that, the fault lies with the laptop screen
If it does not work on that, the fault is with the graphics chip on the laptop
If it was working ok then suddenly died, check to see if you can boot to safe mode (F8)
repost the results
Jan 01, 2011 | HP Compaq Presario CQ50-210US Notebook
Hi i have problem with my HP COMPAQ PRESARIO V2000 laptop at first it developed 4 lines at the bottom of the screen then after a few days the light went off how can i solve it i need it badly i...
It could be due to Physical Memory (RAM) error. Replace the RAM and hopefully your system will be file.
Memory Malfunction usually provokes such kind of problem.
Bit if it is not the case of RAM and you are not able to boot to the system.
just download "Hiren's Boot CD", here si the download link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and extract it with winzip or Winrar.
Burn the ISO image and boot the system using "Hiren's Boot CD" (Set the BIos to Boot from CD-ROM).
You can now easily backup your important data to a USB external Hard drive or to a Network location.
That's it.
Rate this Solution.
Jan 07, 2010 | HP Compaq Presario V2000 Notebook
Have a presario 700 and want to upgrade the ram. Where is it located and how much can I add. tried pushing F1 when starting to get the screen that tells you
  • Maximum Memory: 384MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 128MB non-removable
  • Open the bottom plate of the laptop and read the current information on the ram inside. this will tell you the type to buy....try http://www.pricewatch.com to buy it
    Oct 24, 2009 | Compaq Presario 700 470024-192 Notebook
    Installed more memory into Compaq V2000
    The new ram you have installed, is it the same speed/type as what is already in the system?
    Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
    http://www.bioscentral.com/beepcodes/compaqbeep.htm
    Jan 17, 2009 | HP Compaq Presario V2000 Notebook
    Compaq
    Hi Tom,
    Nice of you to do a direct "Ask Me"
    Initially, the model is one I am not familiar with. But, a Compaq is a Compaq and a laptop is a laptop. Based on your description:
    an IRQ and/or a hardware problem.
    You could try (temporarily): removing the battery and using the laptop on AC adapter/charger only; removing any or all of the add-on cards; switching/removing any of the memories; removing connector of built-in touchpad and/or removing FDD/CD.
    On all of the above, I would suspect either the battery or the touchpad more.
    Incidentally, may I inquire where locally were you able to acquire the keyboards. I have need for two (2), both for Compaq Presario 2100s.
    Good luck and Thank you for using FixYa. Happy Holidays.
    Dec 15, 2008 | HP Compaq Presario V2000 Notebook
    Hard drive failure compaq presario 2200
    If the bios is showing no ide, means that your ide hard drive is not being detected.
    This can be caused by some motherboard failure, some bad cable connection or caddie connection or bad hard drive.
    Nov 05, 2008 | HP Compaq Presario 2200 Notebook
    I want Upgrade my computer memory
    You need DDR PC 2700 184pin memory. Your machine will support upto 2g.
    You can buy this memory from anywhere at cheap prices.
    Hope this helps
    Regards
    Oct 16, 2008 | Compaq Presario 5000 PC Desktop
    Compaq Presario R3000 (intel) 2800 Reset 4 or 5 time a day
    Kees,
    It sounds like you have fried motherboard. If that's the case, you have to get it serviced by a place your manufacturer recommends. Sometimes the cost can be greater than just buying a new laptop, so shop around and see what you can find price-wise.
    Please let me know if this helps. Good luck!
    Feb 29, 2008 | Compaq Presario R3000 Notebook
    Compaq Presario Notebook Logo
    261 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
