Question about ECS 945GZT-M (V1.0) Motherboard
Ram Upgrate on 945gzt-m motherboard
I am planning to set 1 GB DDR2 667MHz ram on this board because I can’t find 533MHz in the place where I live. Does any one have try to set a faster ram than specification by manufactured and how the motherboard behaves? Does it going to break it or it will lower the speed of the ram to her optimum working level?
    Scholar:
  • 57 Answers
Sometimes motherboards have the option through BIOS to change bus speeds, but not the memory chips. Usually, the wrong speed will just not work. It won't fry anything, it will just give you long beeps and won't boot up. I've not put any onto a board like yours, but I did try 667MHz chips with one I had with the same memory specs (400/533MHz) as yours and they did not work. You might consider mail order. Newegg.com has pretty good prices. They are very reputable and have very good customer service.
Posted on Jan 23, 2009
Problems with new ram
This = NO
The Foxconn P4M800P7MB-RS2H motherboard supports ram memory that is either 400MegaHertz, or 533MHz.
You have installed 667MHz ram memory.
http://www.play.com/PC/PCs/4-/3274794/-/Product.html
You also need to watch the Front Side Bus (FSB) of the processor you are using.
Ram memory typically operates at HALF of the FSB of the Processor.
Processor FSB support is 800MHz maximum.
Half of that is 400MHz.
You CAN use 533MHz ram memory, however.
(This is DDR2 Sdram ram memory.
PC2-3200 is DDR2 at 400MHz.
PC2-4200 is DDR2 at 533MHz. (Also known as PC2-4300. Depends on the ram memory manufacturer.
PC2-3200 actually operates at 200MHz. { Max} It is 'Dual Pumped'
PC2-4200 actually operates at 266MHz )
What to do?
Hopefully you saved the carton/s the ram memory came in.
Ship them back, get the ram memory you need.
ALSO;
What is the FSB of the Processor you have installed?
Don't know?
Post back in a Comment as to the model name, and model number.
(Example; Intel Pentium D model 805,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_D_microprocessors#.22Smithfield.22_.2890_nm.29
FSB support is 533MHz
No, you cannot use 533MHz ram memory. { PC2-4200 }
PC2-3200 is the max.
Pentium D model 820 for example, you can )
Nov 18, 2011 | E-Machines Computers & Internet
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
The board has two 240-pin DIMM sockets and supports the following memory features:
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
2 GB maximum total system memory
Minimum total system memory: 128 MB
Non-ECC DIMMs
Serial Presence Detect
DDR2 533 or DDR2 400 SDRAM DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
My motherboard is IntelD845PESV. i use 512 mb DDR 1 RAm & 64 mb Nvidia Geforce 2 Mx/Mx 400 AGP card. Now, i want to upgrate the AGP and RAM . In the intel site maximum RAM supported by this...
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
Hope this helps.
Nov 09, 2009 | Intel D845PESV Motherboard
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Foxconn m/b memory capabilities?
YOU HAVE TO CALL THE MANIFACTURE OF YOU PRODUCT AND ASK TO SEE IF THE SYSTEM WILL SUPPORT MORE MEMORY
LETS SAY YOUR USING VISTA 32BIT, SHARE VEDIO UP TO 860MB, MOST SYSTEMS WILL ALLOW 3-4 GB, BUT SOME MANIFACTURE SYSTEMS MAY ONLY ALLOW 1 GB RAM, THE BOARD MANIFACTURE MAY SUPPORT 4GB BUT THE MANIFACTURE MAY ONLY ALLOW 1-4 GB OF RAM.
CONTACT ME IF YOU NEED MORE HELP
Jan 27, 2009 | Foxconn 6627MA-RS2H Motherboard
Upgrade Ram
No it wont take 800MHz RAM...
Using the DDR2 slots u can have 400MHz sticks (rare stuff), or 533MHz sticks
Using the DDR1 slots u can have 333MHz or 400MHz
Let me know...
Matt
Jan 20, 2009 | EliteGroup 945GZT-M (V1.0) Motherboard
Can i upgrade RAM from 533MHZ to 667MHZ for P4M800P7MA?
Please try to upgrade your BIOS, it may solve the issue.
Jan 14, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
ECS 945GZT-M (V1.0) Motherboard Logo
218 people viewed this question
Top ECS Computers & Internet Experts
David
David
mitch_3020
mitch_3020
Coss
Are you an ECS Computer and Internet Expert? Answer questions, earn points and help others
