Question about ASUS Laptop Keyboard for Asus Eee PC
How to unlock my keyboard asus k55v series - ASUS Laptop Keyboard for Asus Eee PC
I have an asus k55v & sometimes the keyboard locks
Hello.
The computer's keyboard driver is outdated that's why it's acting like that. It will get fixed by updating it. Go to the Device Manager.
Right Click on Computer. Click Manage. Then go to Device Manager.
Right click on the keyboard driver and click on update. You can also use RadarSync if you want to make sure that all drivers are updated so that you won't get any failures in the computer. You can get RadarSync from here http://radarsync.com/driverupdater
Let me know if you have any questions.
David
Apr 12, 2013 | Computers & Internet
How to access asus K55V bios setup
I have exactly the same problem with my ASUS K55V. I am trying to boot Ubuntu 13.04 from USB but Windows 8 keeps appearing on my screen and I have the impression that with every further Windows boot I am closer to kick this annoying laptop out of the window.
Mar 18, 2013 | ASUS K55VD-DS71 15.6" Notebook
The keyboard on my husbands asus is locked and he can't unlock it ..HELP HIM PLEASE!
Press the Windows logo key (bottom left of the keyboard) and the letter L at the same time to unlock and lock the keyboard.
Regards.
Apr 24, 2011 | ASUS G73JHA1 Notebook
I am tryin to figure out what type of motherboard i have and compatable ones i can use. i have an asus g72g series
Asus G72gx Series Laptop Part Replacement:<br>
<a href="http://www.laptopparteshop.com/asus-g72-g72gx-keyboard-replacement.html">Asus G72gx Series keyboard replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">Asus G72gx Series white keyboard replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-a52-k52-g51-g60-g72-g73-series-backlit-keyboard.html">Asus G72gx Series backlit keyboard replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g72gx-battery-replacement.html">Asus G72gx Series battery replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g72gx-cpu-fan-replacement.html">Asus G72gx Series cpu cooling fan replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g72gx-lcd-hinge-replacement.html">Asus G72gx Series laptop hinges replacement</a>
<a href="http://www.laptopparteshop.com/asus-g72gx-lcd-cable-replacement.html">Asus G72gx Series video cable replacement</a>
Apr 06, 2011 | ASUS G71G, G71V, G72G, G72Gx, G72Gx-A1...
Problem: remove keyboard ASUS K72JK-TY043V.Thanks
The Asus K72JK-TY043V Notebook PC is one of the Asus K series of Notebook PC's.
This shows how to remove the Keyboard,
http://www.insidemylaptop.com/disassemble-asus-k-series-notebook/
Shown is a disassembly guide, and of course you do not need that.
What I am referencing to is midway down the page under the bold heading >
Removing Keyboard.
The Keyboard is held in, by plastic tabs that are on the Palm Rest Cover.
These tabs are spring loaded. You press against each spring loaded tab, and depress it.
This action unlocks the Keyboard from the spring loaded tab.
There are Five spring loaded tabs.
The spring loaded tabs are located above the following keys;
1) Esc key
2) F5 key
3) F9 key
4) Prt Scr
5) End
Use a small flat bladed screwdriver such as a Jewelers flat tipped screwdriver.
Carefully press the tab TOWARDS to LCD screen.
Once a tab is depressed it unlocks. Go to the next tab.
The back of the Keyboard is towards the LCD screen.
Lift up on the back of the Keyboard.
DO NOT try to remove it at this time, as there is a flat cable attached to the Keyboard.
The Keyboard cable is an FFC.
Flat Flex Cable.
The Keyboard FFC does NOT have a connector attached to it.
The connector is permanently mounted to the motherboard.
The Keyboard's FFC removes from the connector on the motherboard. Just a flat cable hanging from the Keyboard.
The connector on the motherboard is a ZIF connector.
Zero Insertion Force.
This particular ZIF connector has a Lock Clip on it, that is slid slightly to one side.
As you view the flat flex cable coming into the connector, and above the connector, the clip is slid to the Left to unlock.
NOT very far. Approximately 2 Millimeters, or close to 1/16th of an inch.
Have questions please post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | ASUS K50IJ-C1 Notebook
HOW TO USE NUMBERS ON LETTERS UIOJKLM ON ASUS A6R SERIES
You Have to press Fn key - and Num lock key at the same time and you will be able to use numbers on the Letters on Your keyboard.
Jun 27, 2010 | ASUS Laptop Keyboard for Asus T9400 Series...
Keyboard
you can use the On Screen Keyboard , please follow the bellow steps:-
1.click on start [Bottom at laft] after that
2. Programms
3. Accessories
4. accessibility
5. on screen keyboard
Jan 19, 2010 | ASUS Essentio Desktop with Intel Pentium...
ASUS Laptop Keyboard for Asus Eee PC Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
