Question about True TSSU-48-12-ADA Sandwich/Salad Unit, 12 Cu. Ft., 4 dp Clear poly pans, 2 doors, 4 Shelves TSSU4812ADA, TSSU48-12-ADA, TSSU-4812-ADA, TSSU-48-12ADA, TSSU-48-12-AD, TSSU-48-12-A, TSSU-48-12, TSSU-48
TSSU4812 refregirator making clicking sound and not cooling
My TSSU4812 is not cooling. It is blowing warm air (not cool air) - I cannot tell if compressor turns on or not (I don't know how to tell - it might be turning on and off since it gets hot). Here are the steps I took to diagnose so far: 1) Cleaned the dirty condensor. 2) Keep it unplugged for 10 - 20 minutes. Plug it back in. 3) All fans inside and outside work. 4) Hear a clicking sound. 5) Wait about 20 or 30 seconds. 6) Hear another clicking sound - withing 1 or 2 seconds, another clicking sound but this this time a little different (like an "electric" sounding click) 7) Wait another 30 seconds, same two clicks almost a second apart (as in number 6 above) And the cycle continues. Is it the relays or the capacitor that needs replacement? Also, after leaving plugged in compressor feels hot - can touch for about 2 to 4 seconds without getting too uncomfortably hot. How do I diagnose more to see if its low on freon, bad relays, bad capacitor, or compressor is bad? Thanks
    New Friend:
  • 39 Answers
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Posted on Apr 18, 2013
geemarie
  • 876 Answers
SOURCE: true freezer
Just to make sure--is the freezer plugged into a GFI outlet and is the little red button pushed in? Is it on it's on circuit and has it thrown the breaker?Have you tried a different outlet? Do you have any lights at all- showing power? did you have a power outage? If you had apower outage and it ruined your freezer, your homeowners insurance may cover it. I would have it looked at for an estimate.Ask ahead what a service call costs, and make a decision from there.
Posted on Aug 18, 2008
  • 1253 Answers
SOURCE: Freezer Not Fan not running!
Most all commercial freezers have some sort of fan delay/ defrost termination device. Commonly called a "Klixon" (pronounced clicks-on). It is a device that is attached to the evap. It's function is to terminate the defrost cycle when the evap reaches a certain temp, say about 50 degrees or so, to ensure there is no build up of frost/ ice on the evap. It then allows the compressor to run, and cool the evap down to a reasonable temp., say about 20 degrees, and then let the evap fan come on. It prevents overloading the compressor during a high temp condition, and it also prevents circulating warm air left from the defrost cycle. I believe this device is most likely your problem. With no air circulating, the box will no cool down.. I have seen them burn and/or slhort internally. They can come apart. too. I would look here for that problem. the True manufacturing website does not give alot of info on this piece of equipment, such as a wiring diagram but manuals are available.
Check this out and let me know how it comes out.
Posted on May 21, 2009
  • 40 Answers
SOURCE: fans inside freezer will not turn - no cooling -
The fans are controlled with a clixon that has a cut in at 5 degrees, and cut out at 20 degrees. If the unit is running and the fans are not comng on then I would have to say you are out of freon. But your condensor fan could be running and the compressor NOT be running which could be a problem with your compressor. Find out if your compressor is running by taking an amp draw. If compressor IS running then you are low on freon. If the compressor is running and your evaporator coil is cold and your fans AREN'T coming on then your clixon is bad.
Posted on Sep 26, 2009
  • 193 Answers
SOURCE: replaced run cap, motor windings ohm out good,
Probably locked rotor. This happens sumetims when the connecting rod breaks or seizes up on the crank shaft. Seperate your power cord ar some point so that you can put an amp meter around just one of the hot wires. It should be 10.2 amps maximum. I think you will see it spike to 25 amps for 2 to 3 seconds when the compressor tries to start. That almost immediately kicks out the overload. This compressor is not rebuildable. so it will require a new one if it is what I think.
Posted on Sep 28, 2010
Testimonial: "thanks , still need your help"
  • 185 Answers
SOURCE: compressor runs bypassed thermostat with wire that
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Posted on Mar 30, 2011
Upright freezer door was left ajar. The alarm keeps sounding, can you tell me where the reset button is located.
Hello Deena;
My name is Peter. I am a retired field service refrigeration technician.
There is no reset for the alarm. The alarm goes off when you are not maintaining temperature.
During the time the door was ajar, warm air got into the freezer either icing up and locking the cooling fan or forming a block of ice on the cooling coils (Restricting cooling air flow.)
The best thing you can do, unless you want a $300.00 plus service call to defrost everything, is to turn power off to the freezer. Open the freezer door. Have plenty of old towels to soak up the water in the bottom of the freezer as it defrost.
You did not provide a model number which is located on the inside wall of the freezer. Every 8-10 hours your freezer will completely shout down for 20-30 minutes where only the light works and the defrost heater turns on. The ice build up is too much for the defrost heater to handle.
In some freezers the defrost mode is in the control board, in others it is a separate component that you can repeat trip using a flat head screw drive.
Jan 26, 2016 | Freezers
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
Fan blowing warm air food not freezeing
the ptc overload/relay on the compressors dead so the compressor cannot start,therefore the unit cannot cool,replace the ptc and it will run again
Aug 03, 2011 | Freezers
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
I keep my freezer in my garage, and It is warm out there, but I've noticed that the sides of my freezer is very warm to touch,on sides is this natural. it has been a very good freezer, and is almost 20 yrs...
Most units now use condenser coils hidden inside the walls of the unit verses exposed in the back. If your unit does not have exposed coils or a forced air cooled condenser then they are most likely in the walls which would make what you are describing completely normal. Just make sure you allow 3 to 4 inches of room around them to let the system cool itself.
Jul 08, 2010 | Kenmore Freezers
The compressor on my refregerator seem to be overheated it is a side by side the insides of the doors are warm and the freezer will not free but it is running there is cool air in freezer
The doors should be warm. There or heaters in the doors or what they call a yodelers loop in the frame around the doors that keeps condensation from forming. Make sure the fan if blowing on the compressor and the fan inside the freezer is also running. If so be sure there is no ice built up on the bottom inside back panel of the freezer. If so you will have a defrost problem and the coil is full of ice and not allowing the air to flow through it and cool the fridge. If there is ice, the heater behind the panel is most likely bad.
Dec 21, 2009 | Whirlpool Freezers
I have a Brandt Apollo frost free fridge freezer which is malfunctioning, it is about four years old. The fridge section is dead whilst he freezer funtions. I noticed also that the interior light had got...
it may be repairable. setting the freezer aside for a moment, check to see if the fans come on when you first plug it in. make sure the vents dont have food debris in front of them. If the fans do not come on, you may be able to simply replace the fan or fans that pull warm air and blow cool air into the fridge. they get there cooling from the same coils and the freezer is working, so must be fans or fan relay
Nov 18, 2009 | Freezers
Only cool air and the food will not freeze.
I'm having the same problem. What do you recommend?
Oct 26, 2009 | Frigidaire Freezers
Left outside is very warm & inside products are thawing, what can be wrong?
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 03, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Won't get cold enough
sounds like a sealed system problem lack of freon, possible tubing leak
May 03, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
True TSSU-48-12-ADA Sandwich/Salad Unit, 12 Cu. Ft., 4 dp Clear poly pans, 2 doors, 4 Shelves TSSU4812ADA, TSSU48-12-ADA, TSSU-4812-ADA, TSSU-48-12ADA, TSSU-48-12-AD, TSSU-48-12-A, TSSU-48-12, TSSU-48 Logo
196 people viewed this question
Top True Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Freezer Expert? Answer questions, earn points and help others
