Question about Belkin F1DK102P 2-port KVM Switch
When switching between laptop and monitor the monitor screen does not work
When booting up both an xp pc and a laptop, the display on the laptop sometimes appears to be upside down. Have to reboot laptop to rectify this but then the main monitor stays blank when we try to switch between the two. I have installed 10 switches and this is only happening on 2 pc's
5 Suggested Answers
  • 624 Answers
SOURCE: Belkin KVM 2 port switch
Sounds like its not detecting video on the 2nd port. Have you tried switching the computer on port 1 to 2 yet? If the problem moves then I would suspect that computers video card or the cable that connects it to the KVM. Let us know what happens or if you need more assistance.
Posted on Jul 05, 2007
DJYar
  • 41 Answers
SOURCE: Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Posted on Aug 23, 2007
SOURCE: switching
The switching software that you installed on your computer when you installed the KVM includes an optional setting called "scan" that can be set to automatically page between the two displays.
This is most often used when the device is used for network or server status monitoring. If you configured that to switch every one second I can see how that would be very annoying.
Check the configuration of the switching software to verify that the scan setting is turned off.
Posted on Nov 14, 2007
dcolvard
  • 65 Answers
SOURCE: New Computer Won't Switch Back
You should be able to press Scroll Lock twice and then the up arrow to go back. Have you tried that?
Here is a link to the original manual http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f1dl102p.pdf
Posted on Mar 20, 2009
Screen is blank how do I get it to work again
Do you need the external monitor to switch it back to internal monitor or both on?
Feb 07, 2012 | Lenovo 3000 G530 PC Notebook
Can't connect to external monitor or to Sony bravia tv. When vga connected nothing happens at all on laptop but external monitor says " check cable" ( have tried another cable ). If connected in power off...
You need to:
- Connect everything with the laptop turned off
- Boot the laptop
- Use the Fn key plus F8 or F9 (I'm trying from a small picture of the keyboard!) to cycle through the external display options.
Dec 22, 2009 | Toshiba Satellite Pro L300 Notebook
ASUS Eee PC 90 XP. Wont boot only displays vetical lines.
Did you try a external monitor to see is it works mine is doing the same think so I hooked up a external monitor and the computer is booting correctly i had to hit fcn and f5 for monitor to display. I think it might be a loose connection in the laptop.
May 16, 2009 | ASUS Eee PC 900 Notebook
Laptop to external monitor problems
Right click anywhere on Desktop> Properties>Settings> Try to lower Screen resolution.
Mar 18, 2009 | Toshiba Satellite A135-S4527 Notebook
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
Monitor not working
try going to safe mode,restart pc then press f8 for advance boot menu,go to safe mode,choose administrator,reenable display adapter again..eiether thru device manager or display properties
Jun 25, 2008 | Acer Aspire 3680 Laptop
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Belkin F1DK102P 2-port KVM Switch Logo
182 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
