This tutorial will help you in creating a bootable USB drive of
Windows Vista which you can use to install Vista in any system. It
might become very useful when you don't have access to DVD drive.
1. First format your USB drive in NTFS
file system. You can do it by attaching your USB drive to your system and then format it from My Computer window.
2. Now open
Command Prompt window from Start menu. Right-click on Command Prompt
entry in start menu and select "Run as administrator" option.
3. Now type
diskpart in Command Prompt window and press Enter. It'll launch DiskPart program:
4. Now provide following command:
list volume
It'll show a list of all drives in your system. Look for your USB drive entry. As in the below screenshot, the USB drive is "
G" which you can determine from its "
Type" entry.
Now you have to select the USB drive volume by providing
select volume no. command. Since in our case volume no. of USB drive is "Volume 4", the command would be:
select volume 4
Now we have to make this drive active. So provide
active command:
active
Now exit from DiskPart using
exit command.
5. Now we need to create
Boot sector on USB drive. We'll use "
bootsect.exe" utility for this task. You can find this utility in Windows Vista setup disk. It'll be present in "
Boot" directory.
Now provide following command in Command Prompt:
bootsect /nt60 G:
Here
G is drive letter of USB drive. Replace it with the correct drive letter if your system has some other letter for USB drive.
6. At last, copy all files/folders from Vista Setup DVD to your USB drive and you have done.
Now you can boot using your USB drive and can install Windows Vista in any system.
Thanks to Dave Glover for this info...
