Question about Dell 5E.L2J04.011 Backlight Inverter 4H.L2J02.A04
Power on not working
None
I have power but none of the window go up or down
If you have power to the master switch, the switch it self could be bad. Usually the drivers window is the first to quit. the others work. If none are working, the window lock could be set or broken also. Stat with the drivers door window and manually apply power to the window motor. If it works fine replace the master switch
Oct 01, 2016 | 2001 Buick LeSabre
None of the keys on my tk 762 working
If none works except POWER, Check in programmation. Maybe someone messed with the "Key assignement".
If Power also doesnt work, Open radio and check for a disconnected flat cable in tthe unit.
If still not working, Part of PCB is defective nor complete facade.
Aug 12, 2012 | Kenwood Tk-762 Transceiver
None of the power windows work.No local or master controls work.
start by checking fuses, then relays. if the main switch goes on driver's door goes out then none of them will work.... i would recommend a new switch not a used one.
May 01, 2010 | 1999 Nissan Altima
2002 Grand Cherokee power windows none work at
check for a broken black wire in the drivers door wiring harness between the body and door.
Jan 08, 2010 | 2002 Jeep Grand Cherokee
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Power windows won't work
try to check the power window relay. I believe its behind steering wheel and cluster.
Jun 21, 2009 | BMW 325 Cars & Trucks
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Remote Control Control Codes
has anyone solved this problem???
Jan 13, 2008 | Audio Players & Recorders
Dell 5E.L2J04.011 Backlight Inverter 4H.L2J02.A04 Logo
19 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
