Question about Vizio GV47LF Television
Vizio BV47L FHDTV10A has a blown power supply
Contacted Vizio, reported that there was a loud crack and flash accross the middle of the screen thent the screen went black. Vizio person told me it was most likely the power supply. I then checked the internet and found power supplies listed up to $160.00. My question is are there any schematics or drawings or directions available that would help me to replace this sysem at home,
    New Friend:
  • 56 Answers
It is very easy to replace the power supply.
- Remove the stand
- Remove the speaker
- Remove the back cover.
- Remove 4 wires connector on the psu.
- Remove the 6 screws on the power supply and replace it with a new one.
Hope it will help.
Posted on Feb 17, 2009
I have a vizio gv42l fhdtv10a I have no picture or sound.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 14, 2016 | Vizio GV42L 42 in. LCD Television
How do I test a High Voltage Transformer on my Vizio VU42L-FHDTV10A?
It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
Oct 31, 2012 | Vizio Televison & Video
Vizio vo42l fhdtv10a has no video with backlight on.
May or may not be worth fixing depending age and cost of set when new--if backlights on could be power supply (NEED TO CHECK all voltages out of power board) or even a main board etc---
May 13, 2012 | Vizio VO42L 42 in. LCD TV
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Oct 18, 2011 | LG 42PG20 42 in. Plasma HDTV
I have a gv47l fhdtv10a lcd. it made a loud pop and went blank. i replaced the fuse on the power board. the tv will power on but the screen stays black and the tv will not power off unless you unplug it....
Something on the power supply board has failed. One or several of the voltages is bad and you don't have full control, no off, no screen voltage, etc. Unless you can troubleshoot switching power supplies, its best left to a repair shop.
May 04, 2010 | Vizio GV47LF Television
I want to know how much a Vizio VU42L FHDTV10A screen costs.
The price range is 500-800 depending where you will get it, try Ebay and look for a non-working one with a good panel (screen), it does not matter why is not working as long as the panel is in good condition.
May 16, 2009 | Televison & Video
Vizio 42" LCD Screen (VW42L FHDTV10A) Screen is cracked
i have a 42" cracked vizio screen, where can i find a replacement screen?
Jan 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV47LF Television Logo
421 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
