Question about Sewing Machines
Singer 4624 I need instructions how to thread the bobbin on a Singer 4624.
    Scholar:
  • 65 Answers
Http://www.everysource.net/search.aspx?qrt5=sewing%20machine%20manuals
Posted on Jan 24, 2009
  • Michaelle
    Michaelle Jan 24, 2009
    you can also try sewusa.com for threading diagrams
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
How do I fix bobbin case for a singer 4624?
I don't know what happened to it that you feel it needs to be replaced, but bobbin cases are available for all models, and they're usually relatively inexpensive. Many sewers, as a matter of fact, routinely have one or two spare cases on hand. I just looked it up, and there's one for sale on EBay for $9.50, including shipping. http://www.ebay.com/itm/BOBBIN-CASE-Singer-3103-3105-3130-3140-3314-3317-3343-360-4325-4624-4814-4817-/271264360513?pt=LH_DefaultDomain_0&hash=item3f289da841.
Oct 15, 2014 | Singer Sewing Machines
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
Singer touch sew 645
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Oct 11, 2013 | Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Bobbin thread too loose in singer 9805c
change the needle
make sure the thread isn't coming off the thread take up lever
clean under the needle plate & bobbin area for lint or loose threads
try a different thread
make sure the fabric & needle & thread are compatable
do you have a manual?
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 9805 ) don't a the C in the box
& click search--if you don't find what you need--contact singer customer service
Mar 19, 2012 | Singer Sewing Machines
Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
393 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
