Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover FloorMate won't pick water up
I have a Hoover Floormate and both the dry vac and wash settings work properly, but I can't get it to pick the water up...it's only been used 2 or 3 times and it worked the first time I used it.
  • Anonymous Mar 21, 2014
    Will not pick up water well. Leaves pooling and dirty water leaking out when in upright position.
  • 39 Answers
Check the plastic flex hose at the base for cracks and/or loose fittings. For a diagram/photos and other information about leaks check the link below.
Floor Cleaner Machine Repair Parts
Posted on Apr 02, 2018
  • 294 Answers
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Posted on Jan 24, 2009
Hoover floormate will not dispense solution
this is the original Hoover Floormate, and may have a few different things that may be wrong. First check the fresh water tank is seated or installed properly. Second, it may be the pin on the actual unit itself that is not pushing in the plunger (located on the water tank) all the way to release the solution. Check for clogs above the brush block assembly the small holes may be plugged with dried sop solution.
Sep 29, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
HOOVER FLOORMATE SPINSCRUB WILL NOT PICK UP WATER
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3030 floormate
Hoover H3030 Parts Link
http://www.usavacuum.com/category-s/86.htm
Jan 16, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate Gets little to no suction when set to both Dry and Wet Pick up.
here is a link the parts for your a h3000 floormate
H3000 Link
http://www.usavacuum.com/category-s/85.htm
Please give me positive feedback.
Dec 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate.
Can't do it. The machine vacuums in both scrub and pick-up. Sorry.
Kirk Thompson
San Juan,PR
Sep 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Does not pick up water
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=529140
Posted by Dreams642 on Apr 20, 2008
I have had my Hoover Floormate for years. It has always worked great but the last few times I used it the amount of water left is tremendous and the container for dirty water was not full at all. I looked at it and the hose going up from the bottom thru the handle is broken how do I fix this.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
807 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
