Question about Maxtor Hard Drive
Jumper setting I removed the setting to make it a slave, but I know forgot hoe the master was set .... Maxtor N256
  • Volinda Grande Jan 24, 2009
    sorry that didn'5 help me, as this HD has2 jumper's it's a old Maxtor n256
  • tonys714cali Mar 01, 2009
    my n256 has 2 jumpers and i have no idea how they were set ,i need some kind of diagram to put these jumpers on my hard drive
The first jumper goes up and down on the two pins just beside the IDE cable slot and the other jumper goes across the top two pins next to it
Posted on Mar 08, 2009
    Problem Solver:
  • 20 Answers
Http://www.datastoragedrive.com/maxtor/maxtorjumper/?action=image
here is the image on how to setup this particular drive up for master/cs/slave
Posted on Jan 23, 2009
  • S203celest
    S203celest Jan 24, 2009
    do you know what model this n256 is?
  • S203celest
    are you sure the two jumpers isnt just the master and cable select (CS) most old HDD's had the cable select jumper set so it would look to you as if there was two physical jumpers installed. here is another link that has all of maxtor and seagates jumper settings for previous models. take consideration that maxtor is seagate too
    http://www.seagate.com/staticfiles/image...
Maxtor n256 60 gb HDD jumper settings
Here take a look at this pdf:
eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
So If this is layout " : : : . : "
then...
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 04, 2012 | Maxtor Computers & Internet
Take a look at this pdf:
then...
slave -----------
Maxtor hd jumper settings n256 91366u4 primary
MAXTOR: no jumpers --> Master
one jumper --> Slave
two jumpers --> Cable Select
Dec 20, 2010 | Maxtor Hard Drive
I need the jumper settings for Maxtor N256 hard drive.
Hard drives have three jumper settings on them.
1.MASTER---MA
2.SLAVE---SL
3 CABLE SELECT----CS
If you have a hard drive on the end (last) on the ribbon cable connectors, then it is the master drive, and should be jumpered as such-- the jumper should be on the MA pins, any drive in the middle of the cable is jumpered as slave and should be on the SL pins.
CS usually causes problems, and I do not use it.
There are no jumpers on the motherboard that need to be changed for the hard drive. The only other settings for the hard drive are in the BIOS.
Please vote 4 thumbs up!!,
James.
Apr 23, 2010 | Maxtor Hard Drive
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
I want to install the Maxtor 32049H2 N256 as slave Hd in my new computer how do I set the jumpers ?
hi frnds... step by step way are following link
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/
or
http://www.easeus.com/resource/install-ide-hard-drive.htm
Apr 25, 2009 | Maxtor Hard Drive
Can not find Jumper diagram on N256 Maxtor model 33073H3
Hello there soggytundra, here's your GEEK-steer ...
Despite your question being posted here 5 days ago, I'll presume you still (and if not, then someone else will) need the answer ...
Virtually all Maxtor drives adhere to the following general rules concerning jumper settings (at least up until now):
= MASTER (M): Insert jumper over the FIRST COMPLETE pair of VERTICAL pins.
Examples:
Xoo o oXooo Xooo
Xoooo Xooo Xooo
= CABE SELECT (CS): Insert jumper over the SECOND COMPLETE pair of VERTICAL pins.
Examples:
oXo o oXooo oXoo
oXooo Xooo oXoo
= SLAVE (S): Do NOT insert ANY jumpers (or at least NONE VERTICALLY, but you may HORIZONTALLY across the TOP row as simply a means of storing the jumper).
Examples:
ooo o ooooo oooo oooXX oooXX ooXX
ooooo oooo oooo ooooo oooo oooo
TIP: As a general rule, if you KNOW the role of the jumper capable device you're installing, it is better to NOT use Cable Select (CS). In this case you do, therefore it would be best to specifically designate the (33073H3) drive as (secondary) Slave [and your other (primary) drive as Master].
Good luck and GOD-speed. Please post back if you have any further questions, and/or just to let me (and others in similar need) know how well this steers to solution.
"Today's the best day of my life...and NOW you're part of it!"
Mar 28, 2009 | Maxtor Hard Drive
Jumper setting for maxtor n256 diamondmax vl 40 5400 rpm
There is usually a diagram on the drive showing the jumper configuration.
Mar 16, 2009 | Maxtor Hard Drive
Maxtor Hard Drive Logo
1,239 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
