Question about Harman Kardon AVR 500 Receiver
My harman kardon avr 500, i can get sound only in analog mode surround off, when test tone the right front speaker is not working, what should i do?
2 Suggested Answers
  • 4234 Answers
SOURCE: Harman Kardon AVR 500 Only works in NON-Surff mode ?
This is a good indication that the surround processing section has a problem. This can be anything from a supply voltage being missing to a defective processing IC. Without testing inside the unit, it wil be difficult to determine. With surround procesing turned off, the entire section is bypassed. This is why standard stereo mode sounds OK. The static sound is digital noise and can be poor processing or a bad D/A converter IC.
Hope this helps,
Dan
Posted on Feb 26, 2010
Harman Kardon AVR 1550 left and right speakers don't work during tone test. Just set it up after house move
Might be an idea to look inside the unit for damage caused by the move.
Is there anyway that left and right speaker channels can be accidentally switched off?
May 03, 2018 | Harman Kardon Audio Players & Recorders
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
My Harmon Kardon AVR 500 sound doesn't work, I disconnected speakers, re connected & reset protection. Nos ound not even on test mode
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Feb 09, 2011 | Harman Kardon AVR 500 Receiver
I hope this mail finds you well.i am not getting sound from the surround and center speakers.when i test my speakers i only get sound from the front speakers.
hi,
check ur speaker connection first or may be ur receivers speaker setup have some problem. except frond speaker all the others will be off mode. change the speaker setting.
press osd button on the remote to bring audio setup. select ur speakers large or Small or large according to ur speakers. then test again.
if u connected an analog audio input then press surr (surround mode button) to select the mod you want)
ok
Dec 18, 2010 | Harman Kardon AVR 7000
The one front speaker channel is not working. is there anything one can do short of a technician looking at it?
Yes, you can isolate the failure mode somewhat by swapping the speakers and the speaker cables, noting what input(s) are affected, swapping its cables if ONLY ONE fails.
Onboard FM is the best sound source to use for speaker isolation problems as it is does not involve external cabling. Or you could use the onboard speaker level test tones for the same reason.
May 29, 2010 | Harman Kardon AVR 500 Receiver
Hope this helps,
Dan
Feb 26, 2010 | Harman Kardon AVR 500 Receiver
No output from R surround speaker in Harman Kardon AVR 210
the amp that runs the R surround speaker is or has went out in the main amp! also switch speakers around to make sure that one is not blown!
Jan 02, 2009 | Harman Kardon Audio Players & Recorders
Harman Kardon AVR 500 Receiver Logo
61 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
