Question about Dishwashers
Maytag dishwasher model number mdbh 969as flashes cycle started yet no water going into the dishwasher to start cycle
  • 3422 Answers
SOURCE: Dishwasher won't start
If the unit won't start, but "hums", then the motor itself may need replacing (you need to check for 120V at the motor harness). If the control itself is bad, then you would have to replace the control. You mentioned that the door didn't work right - if that is the case, the door switches may not be making contact properly, thus preventing the motor from starting (the door has to be closed properly for it to start).
If you have any other problems please ask me.
Goodluck,
Please don't forget to rate me as fixya
Posted on Feb 09, 2008
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
SOURCE: ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Posted on Feb 14, 2009
SOURCE: my maytag 200 quiet series dishwasher has a button
The control panel has bee locked. Press and hold the heated dry button for 3 seconds until the light next to the lock "3" button goes off. This feature is to prevent small children from starting it. Locking the controls works the same way, hold the heated dry button for 3 seconds will turn it back on.
Posted on Jan 15, 2010
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Maytag jetclean dishwasher eq plus
What is the model number?
Jun 04, 2013 | Dishwashers
Why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
May 04, 2012 | Whirlpool Dishwashers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Nov 05, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Dishwasher Quiet Series 200
The 3 symbol on the face control panel light is on and starts flashing anytime you push any other button, and is full of water in the bottom of it. My wife says she stopped the washing cycle a couple of days ago but now it wont start back up.
This is a Maytag series 200
Mar 15, 2008 | Dishwashers
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
