Question about Medion (40010998)
MD 97900 laptop Onboard wireless and shortcut key problem.
Months ago now I was traveling over seas (before i had wireless in my home)via plane, so of course i turned off my wireless switch and disabled the card. Now, since we have broadband and a wireless router in the home, I have tried to turn it all back on, and whilst i can enable it from the connections menu, my shortcut keys and wireless switch have all stopped working. Can anyone suggest anything to fix this.
    New Friend:
It is classic hardware problem - north bridge in laptop dies. Reheating of it can fix a problem for one-three months. Normally must change bridge G6150
Posted on Oct 28, 2011
  • 45 Answers
You have to reinstall the Operating System such as Windows XP again nad reinstall all drivers. Thats the only solution, or else you can try to Restore the PC to the Date before you had to fly away! Patrick
Posted on Jul 26, 2007
SOURCE:
I began update. Phone is frozen on iTunes plug in screen
Try holding down your power button and home button at the same time for about 10 seconds. If that does not work, you could try to hold them both down for about 3 seconds then let go of the power button and continue to hold down the home button for about 7 seconds.
Apr 15, 2016 | Apple iPhone 6
How do I know which realtek product to reinstall on my windows7 pc as it has dissapeared
via the bios number that comes up on the screen at boot up. If integrated on motherboard. search the bios number with the words wireless driver .check if there is an air plane mode on the wireless first ! go to control panel under settings and look for device manager and see if wireless device is disabled or set to aeroplane mode.
Oct 28, 2014 | Realtek Semiconductor Computers & Internet
How can I fix at home the product described?
I would file a claim with the airline for damages. There are no parts available to repair those units yourself.
Nov 27, 2017 | Hearthware NuWave Precision Induction...
My inspirion 1501 wont connect to the internert by wireless or lan cable I was using internet on it till few months ago but cant connect now for some reason
you need to go to the dell website and type in your model and bring up the network files and then transfer them via sd card/flashdrive
May 16, 2012 | Dell Computers & Internet
Will not connect to wireless internet,other computers are working fine
Most notebooks have a wireless switch that allows you to enable/disable the wireless transmitter on the system. It is provided to make it easier to use the laptop on an airplane without interfering with the plane's electronics. Can you locate the wireless switch on this unit and ensure that it is turned on?
Feb 28, 2011 | Hannspree HannsBook SN10E22BU3221 Netbook
How to disable wireless on IBM R50 to use on a plane
Software Solution: FN + F5 key enables and disbales wireless 802.11.
Hardware Solution: There should be a hardware switch to disable it at the bottom of the laptop or at the side.
But u cud temporarily on or off it using the software solution.
Feb 28, 2011 | IBM ThinkPad T40 2373 Notebook
How do I put my samsung X120 into a flight safe mode? when flying
All they care when flying is to not have any services running like wireless or like cell phone service. All you have to do is disable your wireless and should be fine. When you turn on air place service on cell phone all it does is turn off transmition, Not like you will be able to get any signal on an air plane unless u have satellite wireless card. Most times all they care is when the plane takes off or on landing. Hope this helps.
May 07, 2010 | Computers & Internet
Wireless switch will not turn on
Common problem with motherboard.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&product=1842189&lang=en&docname=c01300427#c01300427_dv62
Jan 21, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Trig and distance
Debs,
this is solved by starting with the SECOND leg of the flight considered as a triangle.
Find how far DUE east the plane travels (100 km x Cos10 = 83.9 km) using 10 degrees because that is how much is left of the 90 degree quadrent after subtracting the 80 degrres course direction.
Similarly find out how far DUE north the plane travels (100 km x Cos80 = 11 km).
Now get the total flight NORTH = 300 + 11 = 311
- and total EAST = 83.9
Finally, use Pythagoras theorem.to get the total DISTANCE:
square root of ( 311 squared + 83 squared ) = 321 km
Also the DIRECTION from its Tangent of 83 /311 = 14.9 degrees
Dec 19, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Wheelchair tips
Here are some tips
  • When booking your flight: Use a travel agent who is experienced with planning trips for travelers with disabilities.
  • Make your reservation far in advance.
  • If possible, choose an airline with planes that have 30 seats or more - larger planes offer more accessibility.
  • Pick a flight with no changeovers. Call ahead to alert the reservation clerk that you will be traveling with a wheelchair.
  • Arrange for boarding assistance or an aisle chair to get to your seat. And if you can't walk, request an aisle chair during your flight for bathroom use.
  • You should arrive at the airport At least an hour in advance so you can store your fold-up wheelchair on-board. (There is usually room for one wheelchair on a first-come basis).
  • When possible, use gel batteries, as wet batteries must be removed and stored in a separate sealed container.
Sep 14, 2008 | Excel 3000 Wheelchairs Removable Desk...
Computers & Internet Logo
1,811 people viewed this question
Top Medion Computers & Internet Experts
Ekse
Hollyecho Montgomery
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
