Question about Amana ACO1860 Microwave Oven
My micro wave does not heat up anything-everything else work
    President:
  • 267 Answers
MAGNTRON IS BAD costly repair . should be done by service center . voltages in a microwave can and DO KILL if you decide to do the repair please buy or make the proper equipment to discharge the capacator before touching anything inside
Posted on Jan 23, 2009
  • 583 Answers
SOURCE: boiling waer under micro wave lots of steam into
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Posted on Mar 03, 2009
SOURCE: goldstar micro wave model number MVH1615WW
Could be the high voltage capacitor or the diode. Both can easily be checked with the proper ohm meter. It could also be the magnetron tube which you really cannot check. Bill
Posted on May 02, 2009
  • 491 Answers
SOURCE: amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Posted on Oct 24, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: maytag mmv5186aaw micro wave oven works but fails
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some questions to help you or someone you know troubleshoot it:
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
If not, then you probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If the inside light, cooling fan, and turntable are all coming on, then the problem is in the high voltage section, and then the next questions arise:
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
If there's no unusual noise, it may just be a bad connection at the magnetron.
Here are some links you or someone you know can use (in order given) for high voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Posted on Nov 29, 2009
  • 8404 Answers
SOURCE: Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Posted on Mar 24, 2010
My micro wave is not heating everything esle is working . it was working find yesterday it won't heat water today
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 11, 2010 | Maytag MMV4205 Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Mar 03, 2009 | Amana Radarange Microwave Oven
Micro wave is not working
don't know about the red light, but (fancy this) I had the same problem with my microwave tonight. Everything but heat worked. Unplug it, plug it back in. Worked for my GE Spacemaker.
Jan 27, 2009 | Emerson Microwave Ovens
Heard a loud glass breaking noise, now micro-wave will not heat anything. Turntable works, everything looks fine but no heating. Model#R-1505LK
Does it seems to run louder?
I would suspect a shorted high voltage rectifier diode.
We have the full service manual and have uploaded it to our site here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
May 19, 2008 | Sharp Microwave Ovens
Amana ACO1860 Microwave Oven Logo
289 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
