Question about HTC Touch Cell Phone (Unlocked) - Soft Black
My phone touch dialer /keypad not working .
1 to 9, talk, call histroy and other imformation on touch dialer not shown on screen. only blank screen occured on display. I want a new software of touch dialer that will be work on my mobile and tell me how can i get it and how to install in my mobile
  • Anonymous Mar 18, 2009
    i have the same problem , i don't see nothing when i press the dial botton , so how can i get a new one ?
My phone touch keypad is not working, so i am unable to unlock my phone, have any solutions?
Posted on Nov 16, 2010
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
My Samsung Corby GT-S3653 having a touch screen problem. the TOUCH SCREEN dont work but the HARD KEYS is working ?. Please Help me :(
When i type the *#2665# in KEYPAD. i accidentally press the #1 icon then after that i Confirm it. then and then. the Touch Screen dont work but the Hard Keys are working please help me :(
Jun 28, 2012 | Samsung GT-S3653 2 Megapixel Camera-Touch...
Having keypad issues with my HTC EVO. It locks up and the only thing I can do is turn it off. The #pad for the phone dialer malfunctions in that it will read the incorrect numbers from the middle set
It might be a software update problem, or touch screen need to replaced, got ur dealer Incase u have warranty, they will solve it without a penny. Good luck
May 15, 2012 | Google Android
Dear Sir, My Screen Of Samsung S8300 becomes blank whenever I make or call or recieve any call. In this stage the there is no response from the screen, but I can hear and talk on the phone,( I am not...
  1. first problem screen blank out
your mobile has a sensor at the top of you phone which is use to make you screen blank when you keep your phone near your ear to save power during a call.(it may be a sensor malfunction)
2.the vertical lines occurrence is common in all mobiles there's no prb with that!!!!
Jun 14, 2011 | Samsung S8300 Ultra Touch platinium-red...
How to reset an used samsung genio touch?
Reset should be around or under battery. You might need a paper clip to reset it.
Dec 03, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Can't make phone calls with my touch slide always force close. When I try to make a phone call, the screen goes black and I can't view the dialer. Please help!
The problem with the phone is the flexi ribbon thet slides the phone up and down, it is not properly seated that is why it is losing contact with the main board of the phone, hereby resulting in blank screen while dialing or making a call.
The flexi ribbon is known as the flex, so as soon as you replace the flex of your phone, it will work perfectly fine once again.
Have a repairman fix the flex of your phone, and it will be in good condition once again.
Take care
Oct 13, 2010 | HTC Touch Dual Slider Smartphone
Have set screen lock to 1 minute, but when I have to use the keypad in the middle of a call (e.g. in response to instructions to press a number), the keypad locks up in 3 seconds or so. I have to...
ok this model of phone has a sensitive screen and will cause the screen to have a slight malfunction if it is repeatedly touched. you really want that screen locked as soon as it can. you can set the screen to wait a little long but i also have this model of phone and if your talking on it with the screen unlocked you will scramble the calibration on the screen. to repair the calibration you go to the four little dots hit it go to the settings wheel at the bottom right. ok now go to more . go to touch calibrations at go thru the calibration of the touch screen it may tell you that your off a few times but dont worry this is normal. continue thru the steps and save when you feel you have it set to your liking.
Nov 10, 2009 | LG Vu CU920 Cellular Phone
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
KEYPAD ON MY CECT P168
To view the keypad while talking on your CECT P168, at the bottom of the screen there will be an icon in the middle, you'll need to touch the icon and the keypad will be displayed.
Sep 02, 2008 | Dual Electronics CECT P168 Cellular Phone
Touch pad not working
you may need a new keypad flex - but the chocolate is a touchy phone and usually if the keypad flex is going the slider flex is next - the new shiine is built better
Jan 18, 2008 | LG KG800 Cellular Phone
HTC Touch Cell Phone (Unlocked) - Soft Black Logo
395 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
