Question about Refrigerators
Need terminal layout for fgs 80 ha compressor
Need to findout where start and run go on the terminals for embraco compressor fgs 80 ha
  • 1218 Answers
SOURCE: Haier model AES 44B, I need to know how to
Good day,
With a very accurate ohm meter zero'd out, and set to the lowest setting., .......
Check between all terminal options with the probes of the ohm meter until you get the highest reading. ....
The terminal your not on is the COMMON terminal. Record it.
Then, with one probe put it on the common terminal, and check from common to one, and then the other.
the terminal that gives you the highest reading is the start terminal, and then the other is obviously the run terminal.
Posted on Nov 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: frigidaire refrigerator
If you are reading the ohms between all the terminals you should get a reading. If between one you said there was no reading. Try touching one lead to one of all three and the copper tube outside the compressor, if you get a reading the compressor is burned out. In the case of the readings between all three teminals if one shows nothing the internal bi-metal overload is open due to hard starts. Make sure the power is off when doing this and the wires are unpluged from the compressor pins, there position
S R C      start=S Run=R and C=common
Let me know and you are welcome to contact me if you need assistance
Posted on Oct 21, 2007
SOURCE: small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Posted on May 06, 2009
  • 1218 Answers
SOURCE: need diagram for compressor terminals .need to
Good day,
I don't know the terminal layout you asked for but here is a method that will work on any compressor anytime.
Be aware equipment manufacturers will use more than one brand of compressor on a given model.
You will need an ohm meter that has a scale that can be set to a
0 to 20 ohms or near there.
Hold the 2 probes together and set until you get a reading of 0 ohms.
The compressor will have 3 terminals
Take the 2 probes and keep checking between 2 at a time until your sure you get the highest resistance reading.
The terminal your not on is COMMON. record it.
Next put one terminal of the meter on that common terminal, and the other on one of the others one at a time.
The terminal between common and the terminal that gives you the lowest reading is RUN.
The one left is obviously start.
For example. You keep taking readings 2 at a time from all the terminals and the highest reading is 12 ohms. Then the one your not on is Common.
You put one probe on the common terminal and check with the other probe both terminals. One reads 10 ohms, and the other 2 ohms. The terminal that reads 2 ohms is Run. The one that reads 10 ohms is start.
Posted on Dec 18, 2009
SOURCE: I need a start relay for a Kenmore (Danby)
Same EXACT part used in GE Wine Coolers. WR07X10094 markings on the actual part match J531Q32E 6R8M1602 from JAHWA
Posted on Sep 27, 2010
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
My freezer has a bad EMBRACO compressor part # EGZ80HLP. Will an EGZS80HLP replace it ?
The answer to your actual question is--- check your LRA on compressor plate. If voltage hp and LRA are the same then yes. Also if you ohm the terminals on compressor place lead on any terminal and place other lead on grounded surface on cabinet. The will let you know if you a grounded compressor. If none of terminals lead to ground then it could possibly be you relay. If any more info is needed just ask. Thanks Logan
Apr 08, 2014 | Frigidaire Freezers
How to unplug relay from Embraco FGS 80 HA compressor
I was in the same boat as scared it would break... but I just did exactly as the picture you see on it: Stick the screwdriver in the hole and pull back. You will notice just below where you stick the screwdriver in, there is a clip from the other plastic chassis you are trying to detach it from. By puling back, you overcome this clip that was holding it in place. Now what is the next step? It reveals L2, L1, N(neutral), Earth (symbol). Apart from L2, they all are held with a screw....
Mar 18, 2012 | Refrigerators
I have a 10 year old Whirlpool Fridge. Freezer on Top. The other day it stopped getting cold, or even cool. I took a vacuum to the back and bottom of the Fridge, Took off the back panel in the ...
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps .If the compressor is drawing too much current, this may be why it is shutting off.Some relays will be easy to notice the broken with them, they may be burnt. Example one, example two, example three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install a replacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding.----------------- To get replacement part you can get it from www.repairclinic.com.The fault is either the relay or the compressor itself.Start by replacing relay if still the problem is same then its faulty/weak compressor.------------------ Thank you.
Jan 25, 2011 | Refrigerators
Need diagram for compressor terminals .need to know what is common,start and run terminal
As you are looking at the terminals
The nine 'o clock terminal is the common
The 2 'o clock terminal is the run,
The four 'o clock terminal is the start
http://www.lodgingac.carrier.com/Files/LodgingAC/Global/US-en/52CP_Wiring_Diagrams_52cp-2w.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 18, 2009 | Migali Refrigerators
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
Fan runs continuos
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps  ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example oneexample twoexample three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install areplacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed.
Apr 03, 2009 | Refrigerators
Compresor will not kick on. all fans running, thermostat control works, and relays seem fine. The fridge is only 5 years old. Whirlpool 21.0 cu. ft. Top Freezer Refrigerator Plus Ice Maker.
Apr 03, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Need wiring diagram for Ruud Model UPCA-048jas
The wiring on these is pretty straight forward
Basically a contactor, either DPST or DPDT, depending. Input power connects here.
Compressor C terminal connects to one side. R terminal connects to the other. 1 terminal of the run capacitor connects to the terminal with the R terminal of compressor. The other side of run capacitor hooks to S terminal of compressor. One wire of condensor fan hooks with compressor R terminal, the other condensor fan lead hooks with compressor C terminal.
Only things missing from all this is a hard start kit and crankcase heater. Let me know if you want to know how to hook those up.
Jan 29, 2009 | Ruud UAMB Air Conditioner
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Dec 07, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
227 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
