Question about Sewing Machines
The lower stitching on my machine is not consistant, why?
The lower stitching is not working correctly. When I start, the machine will be stitching fine, but two or three inches in, the lower stitch doesn't get pulled up to loop around the top stitch. If I keep going it will start to stitch correctly, but then stop again. The last time I used my machine it worked fine, I am going a bit crazy...
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Wrong size needle or wrong type of thread for the weight or type of fabric. For instance, you should use smaller needle size for light weight fabrics.
Posted on Jan 15, 2013
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
  • 4 Answers
SOURCE: Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Posted on Sep 15, 2008
SewTechWayne
  • 186 Answers
SOURCE: 5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Posted on Jan 31, 2009
  • 97 Answers
SOURCE: My Bernina 1530 stitches are faulty - with loops
This is almost always indicative of an upper tension problem.
First, make sure you're using a good quality thread. If you're using thread that's not of European manufacture, you're probably filling your tension assemblies with little fuzzies. Coats and Clark Dual Duty is the most notorious thread for causing tension issues. If you have a bunch of this thread: throw it away or use it for hand sewing.
Turn your machine off, and use some canned air to blow out your upper tension assembly. (It looks like a couple of little cymbals inside the thread path.) Set your tension dial to 4.5.
When threading, right before you actually thread the needle itself, and with the presser foot up, "floss" the thread back and forth by holding the thread at the top by the spool with your right hand, and down by the needle with your left hand. This will ensure that you force the thread into the tension assembly.
Also ensure that your bobbin is oriented the right direction, but this would be a less common cause for your symptom.
If none of these fixes work, you probably need to have your tensions professionally calibrated.
-R
Posted on Mar 09, 2009
I have the settings correct but it still doesn't zig zag correctly??? what could be wrong???
try a new needle
could also be something wrong with the cam that does the zig zag stitch
would be a good idea to have the machine checked to see if there is something wrong with the cam
Mar 09, 2016 | Husqvarna Viking Emerald 116 Sewing...
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How do I get the stitch length to be consistent? It changes with speed
consistent stitch length depends primarily on tension settings. there are 2 different tension settings on all machines. 1. upper thread tension. 2. bobbin thread tension. since these work together to create the correct stitch length+width, having either of these adjusted inappropriately can significantly impair stitch quality. "knowing' your machine has a lot to do with knowing how tight or loose the tension should be for BOTH settings. the settings will be different for each type of stitch, for each type of needle used, and for each type of thread used, meaning tensions will need to be re-adjusted after each change. in other words, the setting for a medium-width zig-zag with a size 10 needle using mercerized cotton thread to sew light-weight canvas will be completely different than the settings for a regular straight stitch using a size 8 ball tip needle using polyester thread to sew silky lingerie material.
Jun 14, 2014 | Brother PC-420
The thread for the top needle just sews and loops onto the lower thread
I think you are saying that there is a loop showing on the bottom of the lower thread stitch. If the lower stitch looks correct and not bunching, you will need to change the tension on the upper stitch. Make sure that your threads are firmly inserted within the discs also before adjusting the tension. It doesn't take much to change the tension so take it slowly.
Dec 31, 2013 | Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
Can lint get up inside the shaft that raises and lowers the needle?
the needle bar is not hollow,
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
May 01, 2012 | Singer Confidence 7463 Computerized Sewing...
The sewing machine model is CE 5000PRW. The uppe...
It sounds as though the problem is with the tension in the bobbin. Check to make sure the thread is pulled through the tensioner on the bobbin case, if it is check and adjust the tension on the case.
May 21, 2010 | Sewing Machines
Brother VX 1120.... Machine is not making consistent stitches then thread loops and stitch goes straight and half zigzag, thread breaks. Same with straight stitches...will go for about an inch then stitch...
Remove the needle plate, bobbin case and bobbin and clean any lint that has accumulated.
Oil, if the manual indicates you should do this and where it should be done. Some do not as it has to be done by a repair tech.
Re-thread the machine with the presser foot in the up position.
Make sure the bobbin thread is feeding from the bobbin spool in the correct direction and through the proper guides.
If the problem continues, the machine will have to be services by a sewing machine repair person. Take samples of the stitching so they can see what it happening - it could be the timing has to be reset.
Feb 16, 2010 | Brother Sewing Machines
Machine not sewing
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Bargain Box
Feb 01, 2008 | Sewing Machines
Brother CS-6000i
I have the same problem but I believe the answer is to purchase a new shuttle which is the part the bobbin sits in and is most likely scratched or damaged. The quote I got was 40-50 dollars
Oct 27, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
