Question about Epson Stylus Photo R200 InkJet Printer
USB002 error with Epson printer
Printer is selected default printer online and connected to laptop. When trying to print error USB002 is shown and can't print
Basti
  • 1447 Answers
SOURCE: epson tm u220
What type of interface card are you using to connect printer to your computer?
Posted on Apr 04, 2008
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
  • 4 Answers
SOURCE: Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Posted on Jan 26, 2009
  • 15 Answers
SOURCE: CX7400 Epson printer will only print one copy at a time
If you are printing from your computer, in the print options select how many copies you would like to make in the preferences.
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Posted on Feb 18, 2010
I can't Print from my Epson lx-300+II printer it gives communication error what to do now?
ensure that you have the correct driver installed for the printer
do it from online --select the printer make and model and select the right driver to download
Aug 18, 2015 | Epson Office Equipment & Supplies
Tip
Printer Offline Error
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
on Jun 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus t30 error code 2100012c
This error is usually shown when using the AdjProg to try to reset the waste ink counter.
The error code is caused by one of the following:
1. More than one Epson printer is connected (turn any others off)
2. The utility can't connect using the "Auto" setting for the printer "port" (Select the specific printer port using the "Select" button).
This issue is covered with other AdjProg errors in this article
Jan 09, 2013 | Epson Stylus C84 InkJet Printer
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Quicken will not print. Program aborts after error message: Problems communicating to printer: "Dell Photo Printer 944" The specified resource name cannot be found in the image file.
Ensure that your printer is online and all cables are securely attached.
(i) If your printer is on a network, ensure that your network allows you permission to access the printer.
(ii) If you are printing to paper, ensure that the Quicken PDF Printer is not selected.
(iii) If you have more than one printer:
(iv) Ensure that you have selected the correct printer in Quicken. (Select the QuickenFile menu, select Printer Setup, and select the item you want to print. Be sure the correct printer shown in the Printer field. For example, if you are printing a report, select File > Printer Setup > For Reports/Graphs.)
(v)Try making another printer the default printer.
Microsoft Windows Vista:
Click the Microsoft Windows Vista logo (Start button) and select Control Panel.
Under Hardware and Sound, click Printer.
Select the printer and click the Set as default command button.
Microsoft Windows XP:
Click the Microsoft Windows Start button and select Printers and Faxes.
Right-click a printer and select Set as Default Printer.
(vi) Try printing from WordPad or Notepad to be sure Windows is communicating with your printer.
Click the Microsoft Windows Start button, select All Programs or Programs, select Accessories and select WordPad or Notepad.
Enter some text. Select the File menu and select Print.
(vii) If your file does print from WordPad or Notepad, try reinstalling the printer or printer driver.
(viii) If your file does not print from WordPad or Notepad, it probably means that Windows is not communicating with the printer. Check your Windows printer settings.
Thanks for using Fixya.
Good Luck and have a nice day.
May 25, 2010 | Computers & Internet
Jan 14, 2009 | Epson Stylus CX9400 Photo Printer
A communication error has occurred. i can't connect to the printer>>> epson stylus c43sx
A.Unplug and re connect the printer B.Go to Printers and Faxes and click on install printer. When sked for CD or go to list- select - Go to List Select Make Select Model Click OK Make it your default printer
Jun 30, 2007 | Epson Stylus C43SX InkJet Printer
Epson Stylus C60 InkJet Printer still not printing
what is the connection? USB or parallel ? Try1. Disconnect the printer. Unistall the software and driver. Restart the computer. Now re installed and follow precisely the commands. Come off line Disable A/V software Do not connect printer untill prompted. Try2 Go to printers and faxes Click on install printer When asked CD or select from List - take select ftom list. Select the Make. Select the model. Make it the default printer. Try 3. Go to www.fixyourownprinter.com
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
