Question about Intel Play QX3 Monocular Microscope
Intel play qx3 error 77 - Intel Play QX3 Monocular Microscope
  • 72 Answers
SOURCE: I need the driver for my Intel Play QX3 for Vista
This works on my Vista system.
Instruction for installing the QX3 Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3+ downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL Codecs software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on Dec 05, 2008
  • 72 Answers
SOURCE: QX3 micrscope dont work with Vista
Uninstall the existing Intel microscope software and then follow the steps below.
Instruction for installing the QX3 or QX3+ Microscope with Vista
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
Step 2. Download and install the QCODINSTL.EXE software from:
Posted on May 24, 2009
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
Joshi_Z
  • 567 Answers
SOURCE: I have a Intel Play
Hi
I looked up for the drivers for your Intel Play QX3 Microscope on Intel's website.You can check this link
For the time being the driver has not been released for this device.Last driver update was on 8/28/2006 which was before the launch of windows 7.We need to wait for the compatible drivers or use this device on windows XP platform
Thank you
Posted on Oct 01, 2010
  • 72 Answers
SOURCE: need drivers for intel play qx3 for windows 7
Here are the instruction for installing the QX3 (or QX3+) Microscope with Windows 7. You must be using a 32-BIT VERSION. The QX3 is not compatible with 64-bit versions of Windows 7 or Vista.
Before you run the programs below, right click the icon, click on "Properties", click the "Compatibility" tab, check the box next to "Run this program in compatibility mode for:", then choose in the drop-down box "Windows 98 / Windows ME". You should also check "Run as Administrator" if your account is a "Standard user".
Step 1. Download and install the QX3PLUS.EXE software from Intel:
http://tinyurl.com/qx3plus
or
http://downloadcenter.intel.com /Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419& amp;strOSs=All&OSFullName=All%20Operating%20Systems?=eng
http://tinyurl.com/QCODINSTL or
http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=160&DwnldID=2089&agr=N&lang=eng&PrdMap=160
http://tinyurl.com/IntelQX3driverXP or
When the "Found New Hardware" wizard appears you will see a message saying that the driver installation was not successful. Click the Close box. You need to install the driver manually by following these steps:
a. Click START - Select Devices & Printers
b. Right-click on the Intel QX3 Icon and select Properties
c. Click the Hardware tab - click Properties
d. Click Update Driver - select "Browse my computer for driver software"
e. Browse to the folder with the extracted QX3 drivers from Step 3. above. The driver software should install successfully.
Posted on Jul 24, 2011
Intel Play QX3 Monocular Microscope Application Software
The QX3 files are now located at:
QX3 Files for Win7
Comments and suggestions to mmehall [at] yahoo.com
Feb 06, 2014 | Intel Play QX3 Monocular Microscope
INtel Play QX3 microscope 64 bits driver
http://download.cnet.com/Intel-Play-QX3-Microscope/3000-2110_4-104288.html worked for me Win 7 64 bit. You may need to run in compatibility mode. Search for that if that turns out to be the problem.
Aug 02, 2012 | Intel Play QX3 Monocular Microscope
I want to use intel play QX3 with window XP 2007
The QX3 works fine with Windows XP. Just download the latest software from Intel:
-Mark
Feb 07, 2011 | Intel Play QX3 Monocular Microscope
I have a Intel Play QX3 Microscope and a I can't find the driver for Windows 7. What can I do?
Hi
Thank you
Oct 01, 2010 | Intel Play QX3 Monocular Microscope
Vista driver for Intel QX3 Microscope
Jan 10, 2009 | Intel Play QX3 Monocular Microscope
Oct 26, 2008 | Intel Play QX3 Monocular Microscope
Intel Play QX3 Monocular Microscope Logo
221 people viewed this question
Top Intel Science & Laboratory Experts
William McMath
Tom Chichester
Are you an Intel Science and Laboratory Expert? Answer questions, earn points and help others
