Question about Kaz 4100 Cool Mist Humidifier - 1gal
How much water in kaz humidifier - Kaz 4100 Cool Mist Humidifier - 1gal
    President:
  • 2,976 Answers
Fill it to the fill line on the side.
Posted on Jan 18, 2013
Humidifier does not turn on
if your saying that the voltage drops to around 4 volts at the supply transformer at anytime , then id say the load (device connected) is too much for the transformer to supply this most likely is caused by an internal fault in the load (humidifier) also since its a water appliance id say a water leak might be a factor in that as well , taking a look under the cover of the humidifier 4 signs of a water leak (or past one) would be where id start
Nov 11, 2015 | Aprilaire Model 700 Automatic Whole-house...
Water from drain being sucked up by humidifier, water damage
There needs to be a vacuum break in the drain line. This can simply be accomplished by not allowing the drain from the humidifier to be submerged in water, let it breath.
Apr 05, 2014 | Aprilaire 700 120V Power Fan Humidifier...
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
On the HUT200 model. Does not produce the mist
I have read elsewhere on this site that overheating of compressor may be low gas level, but does that mean there is a leak? I have had the machine about 3 years, used over 1000 hours.
Dec 15, 2013 | Kaz Inc Honeywell HUT200 Easy-Care Cool...
Not producing humidity
If this is a unit that has been used for some period of time,it may be clogged and in need of cleaning
Dec 09, 2012 | Kaz inc v3500-n v3500n
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Water is no longer collecting in bucket, but appears to leak out of humidifier. Humidifier also ices up.
Basically there is a drainage blockage from the humidifier to the bucket. Take one for the boys and **** hard on the pipe which very possibly will release the blockage.
May 23, 2010 | Kenmore 54351 Dehumidifier
How do i start this humidifier?
fill with water - the water conducts electricity and in a few minutes will produce steam
Dec 18, 2009 | Kaz Vicks Natural Mist Humidifier...
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Kaz 4100 Cool Mist Humidifier - 1gal Logo
Top Kaz Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Kaz Dehumidifier Expert? Answer questions, earn points and help others
