Question about GE SpaceMaker Microwave Ovens
When I close the door and enter a time for cooking it just clicks but if I lift the door abit it works
Door interlock switch faulty access via removing control panel or case
Posted on Jan 17, 2013
3 Suggested Answers
  • 117 Answers
SOURCE: Microwave stopped working??
Your microwave safety interlock mechanism is faulty. They are hooked right into the main power . Its very complex...the schemnatic looks like a safety system for a nuclear warhead or something -- it's overkill.
But microwaves are involved. Sometimes you can clean them but my experience is taht once they go they're gone because the door latches are just plastic and they do wear down and simply won't have enough material on them to get all the switches to work.
Posted on Jul 14, 2010
miket756
  • 2702 Answers
SOURCE: Our microwave will not cook when the door is
please dont even try this, fix it yourself job!!! yes it is an easy fix!! if you know what you are doing,, but if you dont know what you are doing,,,, well to be blunt,
you could just be finding a fast way of killing yourself!
even with the power plug pulled out the wall scocket and stood on a rubber mat!!! just one tuch across the capacitor and you could very well grow wings!!!!!!!!!!!!!!
do you realy wont to die??? call the guy back to fit a new micro switch in the door lock as its set back deep in side the unit and its a cheep part as well
but just like all fixes,,, its not the parts you pay for,
its knowing how to fit them in that costs you so much
this not knowing could cost you your life???????
play it safe,, please,,
Posted on Oct 21, 2009
Testimonial: "Thank you for your input! I did not know about the capacitor and how lethal it could be. I'm glad that I asked before attempting the repair! Thanks"
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Microwave door switch
See our help file on door switches here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Apr 25, 2013 | Microwave Ovens
Model JVM1443 fan runs all the time when unit is
The top door switch (door sensing switch) is defective, or its mount is loose or broken.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Jan 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Oven Does Not Start Cooking
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If yours is not shown at the parts site or manual site linked above, Please reply back with your brand and model number so we can help you.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Dec 24, 2008 | Frigidaire PLMV168 Microwave Oven
My sharp r520lw microwave stopped working.before it stoped working completely it had a problem with the door switch.if i lifted on the door it would work again.now it doesn't work at all.it won't even let...
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switchor mount trouble can be caused by slamming the door or by opening thedoor while it's cooking without hitting the Stop pad first.
There areplastic mounts inside the microwave which hold the door switches andonto which the door latches lock when you close the door.
Sometimes it'sa broken tab on the switch holder, allowing the switch to rotate justout of position. This tab can be hard to see, since it is under thebottom edge of the switch.
One test that sometimes helps is togently lift up (and/or push down) on the door or handle as you try tostart it. If it works or tries to work, then it's a door switch mount ordoor alignment issue.
If you or someone you know decide to lookinto it, we have critical information on safety, disassembly and doorswitches at our site, and our link is at our listing here on FixYa:.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Sep 12, 2008 | Sharp Microwave Ovens
I have the Panasonic "The Genius" 1300 w microwave. I can not get it to work properly. When I push the time to cook then start, the light comes on (no sound from microwave) the timer goes down...
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In this case, it's probably happening because it;'s not cooking due to a switch problem.
Aug 17, 2008 | Panasonic Microwave Ovens
"cook" on display
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 10, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
New Frigidaire Microwave fan and turntable run constantly, will not cook.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If you don't have warranty coverage for some reason:
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 29, 2008 | Frigidaire Microwave Ovens
Microwave runs on its own
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
Jul 22, 2008 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
