Question about Craftsman Garden
Craftsman lt2000 17hp kohler Has12volts to solenoid and only clicks and doesnt crank. Jumped to starter red cable and starts.
    New Friend:
  • 12 Answers
The battery is weak or needs a charge. Have it load tested at a parts store. It needs about 14 volts to start.
Posted on Jan 16, 2013
lester482529
  • 226 Answers
SOURCE: Craftsman 42" 15.5 Kohler engine won't tunr over.
take it to your loca auto zone or whatever you have there tell them what it came off of they should be able to test it for you.hope this helped'
Posted on Jun 07, 2009
SOURCE: Solenoid/Starter issue 18Horse Kohler Magnum
The starter turns over but will not turn the motor over.
Posted on Apr 11, 2010
huffman49
  • 235 Answers
SOURCE: My Craftsman 15.5 HP was running fine. Then
sounds like you got a wire grounded out somewhere.check for loose wires
Posted on Apr 14, 2010
  • 36 Answers
SOURCE: I HAVE A POULAN MOWER TRACTOR MODEL HD12538B THAT
Try replacing your spark plugs. Make sure its getting gas. Make sure your air filter is nice and clean. Check your fuel filter. and if all those fail try replacing your coil.
Posted on Feb 08, 2011
SOURCE: 18hp kohler engine (grasshopper) won't
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Posted on Sep 23, 2011
2004 Pacifica will not crank. Turn ignition and dash lights work but turning to start no starter engage. Hear relay click but no starter click. Could this be the key ignition tail piece broken?
Hi. If the click you hear when turning key to crank is from a relay start there. The fact you can hear the click means the ignition barrel is doing something and probably OK.
Oct 05, 2017 | Cars & Trucks
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
I have a 445777/0129-E1 engine that won't crank when I turn the ignition key. What should I check next?
The click will be the fuel switch on the carb that opens when the ignition is switched on. When you jumped the battery to the starter did you have the ignition on? If not it won't be getting fuel. If you find the wire that goes from the ignition switch to the starter solenoid (usually mounted on or near the starter motor) and connect the switch end of this to the battery does this crank the engine over? If so then the ignition switch will probably be faulty or have dirty contacts. If not then I'd suspect the starter solenoid.
Sep 21, 2015 | Sears Craftsman 46 in Mulching Tractor...
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
When trying to crank my 23 hp garden tractor (craftsman), it makes a clicking sound everytime I turn the ignition. It may finally crank after 8 to 12 attempts. What is causing this? Is it the solenoid or...
I would start by clean and tighten all cables battery/ solenoid. then if it does it I would jumper across the solenoid from red wire to red wire after the first click happens to see if the starter kicks in each time you touch both post. if it does change solenoid.
Oct 24, 2013 | Craftsman Garden
I have a 96 Dodge Intrepid and it wil not start. it clicks when you try to start it. All of the lights in the car are on. the battery has been charged. it cut off on me a few days ago and i thought i...
solenoid clicking, troubleshooting steps: Run 3 tests to troubleshoot.
1. try to jump start at battery terminals
2. unhook the jumpers and try to jump the solenoid following procedures at http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over (see picture there--make sure car is in park or neutral)
3. Only if #1 and #2 fail to crank the engine, smack the starter motor (not the solenoid) with a hammer and then try to start.
Based on results of above tests, here are solution options:
If smacking the starter is the only test that worked, you have a dead spot on the starter commutator--replace the starter.
If it will jump start but will not crank by jumping the solenoid, check to make sure the battery terminals are clean and tight.
If it will not jump start and will not crank even by jumping the solenoid, the problem is either the cable to the starter or the starter/solenoid itself.
check the big red wire that goes from the battery to the starter and make sure it is strong and tight at both ends. If that is good, replace the starter/solenoid.
If it will not jump start but will crank when the solenoid is jumped, the problem is with the start circuit not getting sufficient current to the solenoid. This usually only happens when there is a separate starter relay (in the engine compartment relay box) that is worn out. Replace the starter relay.
Please let me know if you have questions.
Oct 17, 2010 | 1996 Dodge Intrepid
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
I have craftsman tractor Model 917.272751. Now engine clicks but will not start. I checked Starter. It is good. What is the posible probelm? Thanks
If it just clicks and won't crank, most likely it is your starter solenoid.
You can verify this by "jumping" across the 2 large posts on the solenoid.
If it cranks doing that then the solenoid needs to be replaced
Oct 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower won't start.
Typically if it clicks, its not a safety switch. The click is the solenoid engaging. Bypass the solenoid and see if it cranks. If so suspect a bad solenoid.
Oct 15, 2017 | Craftsman Garden
Garden Logo
159 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
