Question about Denon AVR-2500 Receiver
No sound coming out of speakers
There's sound coming out of the center and rear speakers connections but no sound out of A and B main speakers.
3 Suggested Answers
hawkwatcher
  • 67 Answers
SOURCE: Denon AVR-3300 Center Chanel Sound Problem
My guess is You have dried out electrolytic capacitors causing failure. These receivers when they get over 6 years old start drying out fluid in capacitors especially on regulator p.c.b. causing noisy supply lines. I work for Authorized service center in Michigan If you need repair and Shipping to Michigan is economical let me know kstahl65@att.net
Posted on Feb 15, 2008
  • 979 Answers
SOURCE: I think my amp is broken
Finals/outputs are toast. Get it serviced to get back to sweet music...accordianman
Posted on Mar 09, 2008
Main Speakers Loose Contact
pls. take out your speaker wires and cover the leads with soldering lead and connect it back.
Mar 16, 2013 | Audio Players & Recorders
Shud i get an external equaliser? i'm using MG166CX 16-Channel Mixer as the main mixer.
An external equalizer will not help this at all. The problem is likely within the amp (feeding the main speakers), the connections from the board to the amp, or the speakers themselves. In other words, the answer would be "NO." Best of luck!
Jan 14, 2013 | Music
Speaker sound will only come out of center speakers. The rear and front speakers do not have any sound
first is of course make sure hookup is still ok and then I would have the speakers checked (not likely) and last means a failure in the receiver itself--most shops for a fee will inspect it and give you an estimate.
Nov 06, 2012 | Pioneer VSX-405 Receiver
I am connected to the TV from the sound system. Of my six speakers connected, I can only get sound from the SW, and the front L & R speakers. No sound is coming out of the Center or Rear L & R. ...
You don't say HOW the 'TV' audio is carried to the RT2500? TV's are usually the end of the chain, not a link in it. For multichannel audio you need a multichannel digital source. Is that the TV or would it be the cable/sat box? Try running a digital audio cable from one of those to the RCA.
Dec 27, 2010 | RCA RT2500 System
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Sony center speaker and rear speakers don't work all the time
try using another speaker for the center channel and the left speaker, also watch your ohm load, most of the want a 4 ohm load. try to narrow it down to see if it is the speaker or the amp.
Mar 13, 2009 | Sony Audio Players & Recorders
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
41 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
