Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Will not start
All lights come on but when you try to start . The door does not lock and the machine does not start. If you continue to try to start the lights blink three times. And does not start.
  • Kenmore Master
  • 17,130 Answers
Check the door lock and switch, check the input from the switch to the panel. If this is fine then check for power to the panel.remove the panel and reset the connectors to the panel.
If there is no action even after the panel is fixed with the program proceeding further, it is possible that the program controller unit is faulty.
Posted on Jan 15, 2013
3 Suggested Answers
SOURCE: Kenmore front loading HE3t time light blinks add item light on machine
unplugged machine and that reset the controller the machine started to work as normal.
Posted on Aug 08, 2008
  • 354 Answers
SOURCE: I have a Kenmore Washer Model 48102. When I try to
Check and see if the door is impeded by lint ,gasket or something else. the switch could be out of alignment other wise I would say it is bad. Might want to look online to see if other people have had this problem and wrote a blog about it
Posted on Feb 15, 2011
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
I turn my machine on the lock light is on plus the drum clean & cottons lights are on, try to turn the lock off &bit won't.Perhaps it needs a drum clean but nothing will work
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
May 25, 2015 | Fisher and Paykel Washing Machines
When i Press start the washing machine clicks a few times then red padlock light comes on. Door interlock changed but still happening. Any help appreciated.
I gather that the interlock has been replaced and now the padlock symbol lights up plus some clicking. I think the clicks are the door lock engaging and the padlock just shows this. Do the clicks continue? Does the door stay locked? If so I believe you have a fix.
May 19, 2015 | Indesit Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
When I programme my washing machine the lock light does not come on when the door is closed, therfore it will not start.
Possible that the DOOR lock SWITCH is faulty and so the continuity to the switch and the wiring to the panel must be checked.
If there is no continuity then the switch must be replaced.
Jan 15, 2013 | Indesit W 123 Front Load Washer
Maytag neptune washer MAH-1 start button turns off, does not spin
Hi!
Is it pumping water? If not then pump is bad.
Is the door locking? If the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the console.
Check for continuity across the Door Lock, Spin Enable Switch when the switch actuator button is pressed in. If there is no continuity across the Door Lock, Spin Enable Switch, replace the Door Lock Switch Assembly.(Check for 120 vac across the Door Lock Wax Motor)
Please rate this solution and ask for further clarifications if needed.
Thanks
Rylee
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
'door locked button flashing'
The door lock flashing all time has nothing to do with the weather, or pipes freezing up, it is a fault with the washer.
It is unlikely to be a faulty door lock, but could be a broken door catch spring or door catch problem, make sure you can feel the door latch in securely.
the other probable cause a fault on the main pcb where you programme the washer.
Another prob that can occur is a fault on the mptor caused by the brushes shorting on the motor armature, this in turn can blow a track of the pcb, and giving you the flashing light prob.
I would start by checking the motor first, if you are satisfied that the door is closing o/k.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Car won't start
Hi, does the alarm shut off when you unlock the passenger door?
If it does not I will give you a test that you can do.
1. disconnect the harness anti-theft control module. (loctaion depend were you live USA next to fuse panel Canadian models above the glove box.) Check the continuity between Light Green/Black wire and Black wire of the anti-theft control module.
2. Continuity should not be there with the door lock in, lock or neutral position. With the door lock in-between lock and neutral position (any door) continuity should be present.
3. If continuity is as specified replace the anti-theft control module. If continuity is not as specified, check operation of the door lock switches.I will add that test at bottom.
4. If the door lock switches are ok check the continuity og LIGHT/BLACK wires between anti-theft control module and door lock switches. Check Continuity of BLACK wire between door lock switches and ground. Continuity should be present if Continuity is not present repair harness or connectors.
5. If Continuity is present, check continuity LIGHT GREEN and BLACK wire of anti-theft control module. Continuity should not be present with trunk lock in lock or neutral position. With trunk lock in-between lock and neutral position, Continuity should be present.
6. If Continuity is as specified replace anti-theft control module. If Continuity is not as specified, check operation of truck lock switches. If necessary replace trunk lock switch.
7. If trunk lock switch is ok, check Continuity og LIGHT GREEN wire between anti-theft control module and trunk lock switch. Check Continuity of BLACK wire between trunk lock switch and ground. Continuity should be present. If Continuity is not present repair harness or connectors.
DOOR LOCK SWITCHES
Disconnect 4-pin door lock switch connect (left and right front doors) With door lock in neutral, full lock or full unlock position, there should be no continuity between any terminal and BLACK wire terminal. Continuity should exist between LIGHT GREEN?WHITE wire and BLACK wire terminals with door lock in-between neutral and full lock position. Continuity should exist between LIGHT GREEN/BLACK wire and BLACK wire terminals with door lock in-between neutral and full unlock positions. If continuity is not as described, replaced door lock switch.
Hope this help its a place to start. let me know if you need anything else.
Cheers
Aug 23, 2008 | 1994 Nissan Maxima
Washing Machines Logo
Sal De
fordexpert
Whirlpool
Whirlpool
