Question about Microwave Ovens
Cause of burnt magnetron
We have a GE Spacemaker microwave. My husband cleaned the inside of it and broke the stirrer cover. We ordered a new one. WHen the tech came out he also had a stirrer blade with him. He said, ''I don't know why they sent this but let's put it in anyway...new part for you''. After he left we went to heat up food and it sparked. We called right away and he came back out. He said it looked like it might be arcing so he put cavity filler stuff up on the ceiling under the blade area. It still sparked. Tech #2 came out and said that the blade must be defective and it was arcing...showing me a hot spot on it. He ordered a new one and then relaced it. Still sparking. Tech #3 came and said the magnetron was burnt due to arcing. They referred us to GE, who will replace the microwave for a discounted price. I filed a claim with the appliace company that we bought it from/and serviced it. THey denied the claim stating that the parts they replaced did not cause the magnetron to burn. Is this right? I feel like all we needed was the $7 stirrer cover, they put in a defective part that we didn't need and then our microwave won't work and needs to be replaced. Do I have a leg to stand on here?
    President:
  • 267 Answers
GE microwaves have poor magntrons . with that said . something was wrong with the replacement stirrer . the first spark did damage to the magntron ......too bad you dont have the orig stirrer to put back in just to see what happens ..... i think your stuck,we can think anything we want but we cant prove anything and it would cost more trhan a microwave to fight it in court ...... get a new one , but not a GE
Posted on Jan 23, 2009
    President:
  • 1,214 Answers
This could get legal considering the repair tech's either did not replace the failed parts with the proper ones. If they used or installed defective parts, let GE know what was done and tell them you are unsure if you or members of your family may have been exposed to microwave radiation as a result of the installation of defective parts, and that now that the unit has failed after replacement of the parts, that you feel you may want to pursue further remedy if they choose not to replace the oven at no charge.
I have had success in gaining repairs when letting the manufacturer know that they may have a serious liability issue to face if they don't do the right thing.
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
Stirrer cover cavity magnetron
Please be more specific as to what you need..
Oct 12, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
WHEN IN USE IT MAKES A BUZZING SOUND FOR APPROX. 2-3 SEC. WE SEE A ROUND SPOT WHERE THE PAINT HAS BROWNED ON THE RIGHT WALL ON THE INSIDE OF THE MICROWAVE.
Hopefully this is just some grease on the waveguide cover / stirrer cover or the cavity wall.
If it's progressed to waveguide or magnetron damage, that gets expensive.
The first step is to inspect and clean these areas and replace the cover if it is damaged.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If the cavity metal is chipped or discolored, the area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover / stirrer cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Jun 20, 2011 | GE Profile Spacemaker JVM1871 Microwave...
I have a GE Spacemaker microwave JVM1430BD002 There's a circular panel inside on the upper surface that's all greasy around the edges. It has arrows with 'open' close' on it but I can't get it to move. I'm...
That's the stirrer cover. It does need to removed and cleaned, and the stirrer parts above it, too. so that the grease will not eventually cause arcing and damage.
Your owner's manual should cover that. If you've misplaced yours, you can download GE owner's manuals and installation instructions here.
May 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The inside fan cover started peeling and broke, i can't use the oven and need help!
its the fan inside the oven cavity on top, its part # AP3671492 and is a G.E. part# called the Cover,Stirrer Fan still manufactured
Sep 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lubricant leak from round disk on the inside top of the microwave (piece has open and close written on it).
That would be the stirrer cover, and the leak is probably grease that has gotten into the area above the cover.
The cover, stirrer and exposed area under the cover needs to be cleaned thoroughly to prevent arcing and to allow for proper stirrer of the weaves for even cooking.
You can find handy exploded views and order any needed parts by model number here.
Sep 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV1153BAW
This is the stirrer cover. It is important. It is to keep food particles and grease out of the stirrer and waveguide area.
If grease or food particles build up, they can arc, which will cause burn damage to the cover, stirrer, chassis, and/or magnetron.
If you have any arcing, you should remove it for cleaning. Be careful of sharp edges.
The stirrer's job is to stir the microwaves to ensure even heating, even when a turntable is not present or not used.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Maytag MMV1153A Microwave Oven
Maytag MMV1153BAW interior access panel
May 05, 2008 | Sharp R-530BS Microwave Oven
GE JVM1650SH01 quits and asks to reset clock
Thanks musicmale -- i was gonna try the cpu board.. U saved me $$$
Just got off the phone with GE about my Jan 2005 model (not covered by the service bulletin above) They wouldn't cover the kit mentioned in the service bulletin (magnetron, stirrer and diode) but they did say the magnetron was under warranty ( even though the oven came with only 1 year warranty and its now 2 years old) They are sending me a new Magnetron for free but just in case I ordered a new Diode for $31 (WB27X1160) i din't order a new "stirrer" cuz mine is fine.
I'll let you all know if this works. in 3-5 business days.
Dan
Sep 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
381 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
