Question about Exercise & Fitness
My tread mill Image 10.40i will only go back to number 1 when it declines. Goes up ok but want go all the way down.
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
SOURCE: treadmill won't run. trys to start and gives up after 1-3 seconds
i am having the exact problem, any answers to this?
Posted on Dec 29, 2009
SOURCE: walking belt on image 10.0 tread mill slips,
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Posted on Feb 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: I need to find rubber belt for tread mill Dynafit
The only suggestion I have since this manufacturer has gone the way of the dinosaur, is by going to a local dealer that carries industrial belt of different sizes and and shapes you may get lucky and find something. I wish good hunting
Posted on May 17, 2010
Tread mill power is on but treadmill not moving just beeping
Does it need a safety key? Is it in all the way?
you might also need to check the connections in the back of the display and also where they connect inside the front arms down to the motor.
Apr 14, 2014 | Exercise & Fitness
Oma-002mb what the weght can this tread mill work my weght is 125kg can i trainning in this tread mill
yes you can every treadmills made for hourse training can weight for 250 lbs aprox.
Happy new Year.God bless you
Dec 31, 2012 | Star trac ST Fitness 8921 Treadmill
When Iam walking on my treadmill it will change to a very fast speed
hi,
check the speed sensor in ur tread mill. may be it has become dirty. clean it and refix it. u can find out the speed sensor near the motor pulley.
ok
Dec 30, 2010 | Sears Exercise & Fitness
I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
hi,
i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
ok
Dec 26, 2010 | Bowflex Exercise & Fitness
My tread mill looses speed during my workout. the
Apr 10, 2010 | Proform Exercise & Fitness
I can't unfold my proform treadmill
there is a clip latch that u need to move to pull the treadmill back down, its on the left side on top
May 05, 2009 | Proform Exercise & Fitness
Jan 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
79 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
