Question about Watches
Can't figure how to set day of week on
Can't figure how to set day of week on ARMITRON40/8254 MD11239T(R)
  • Watches Master
  • 18,392 Answers
Try this link scroll down to find your watch then download manual
http://www.armitron.com/watch_instructions.asp
Posted on Jan 15, 2013
Change day of the week in casio worldtime watch 3198.
On most digital watches, if you properly set the date and year, the day of the week is preset.
Jan 03, 2013 | Casio G-Shock GW300CA-1V Wrist Watch
No instructions came with my Studio Time Watch
I have/had the same problem....just found this pdf file that shows exactly how to do it and it worked!!!!!!!!!! Not sure if you already returned it or not....
Nov 01, 2012 | Watches
I can't set the day of week on my Casio, CA-53W. Thanks
If the day of the week is incorrect, make sure the date is set correctly. The format on the Casio CA-53W is year first, then month, then day last.
May 31, 2011 | Casio New CASIO CA-53W Water Resistant...
My DZ4067 functions in the non-English day of the week for 21 hours a day now. How do I change it back so the the day of the week is in English for 21 hours a day?
The "day of the week" wheel on your watch actually has 2 settings on it--one for English, one for another language (often French, but could also be Russian, Japanese, Korean, or any other language, depending on the intended distribution of the watch). You'll need to shift the day track over by "half a notch," so to speak, to get things back in alignment.
The crown you use to set your watch can be pulled out into 2 positions. If you pull it all the way out, you set the time. If you pull it half-way out, you can set the day and date. If you turn the crown clockwise, you advance the date. If you turn the crown counter-clockwise, you should be able to change the day of the week. However, instead of turning the day back a full day, stop when you get a day with the correct language on it. At this point, pull the crown out all the way and manually advance the time 12 or 24 hours until the day and date advance as they would when the watch is running. This is to check that you've correctly gotten the day track correctly oriented. You may have to repeat this process a second time to get it right.
Once you have the day back on track, adjust the date and time, and you should be good to go.
Diesel's own directions, which can be found here: http://store.dieseltimeframes.com/common/images/customercare/instructions/ENGLISH/Diesel_Core-Inst_ENG.pdf are pretty cryptic, but they do have a diagram that might help a little bit. You'll want to look at the section for "Day/Date Watch IS02, 507.2-3, 517.2, 2105, 2305, 2405"
May 26, 2011 | Diesel Watch Style # DZ4067
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 | Watches
Need help adjusting the day to english
Usually pulling out the crown to the second position sets the time by turning in one direction and the day by turning it in the other direction. I some you will need to advance the time through 24 hour cycles till you get the proper day displayed and then set the date.
Jun 19, 2010 | Watches
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Watches Logo
284 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
