Pulled off wall but didn't see battery, possibly behind front screen?
SOURCE: The wall mounted thermostat in a condominium unit
i think you may have a fan/control board problem, if the thermostat turns on the fan, and you dont touch it, then the fan stops in a short time...
plus the fan is connected to a control board, like i said those thermostats hardly go bad...
SOURCE: I changed the batteries of
Hello my name is Heath it will be my pleasure to assist you. Take the new batteries out and let the display go completely blank then reinstall the new batteries and the lo batt light should go off.
SOURCE: I have a honeywell ducted
it more than likely has a battery in it,,,, it can be hard wired and still run off batteries,,,,,,, double check it again,,,,,,,,,,,
SOURCE: Blank Screen on thermostat
check your float switch. On your air hander you have 3/4 white pvc coming out of bottom of unit, where the water drains out. If you have a float and your drain line is plugged it will make your tstat go blank. vacuum the drain line where it comes out of the ground outside.
