Question about Maytag MEC5430 Electric Cooktop
One of the burners will not work
The larger main burner will not turn on at all
    Sergeant:
  • 475 Answers
Heating element might be not working in your stove.
Posted on Mar 11, 2013
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
How do I fix my left rear burner that has stopped working?
First of all, you need to test the wiring to that burner. If there is no electricity, then you need to replace the plug in. You can get them at an Appliance parts store. If there is electricity, then all you need to do is get a new burner at Lowes or Home Depot. Sometimes the burner gets a tiny crack in the burner that breaks the continuity.
Sep 01, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
Jun 02, 2011 | GE Cooktops
When I turn any burner on, the ignitors work fine but it takes a very long time for the burners to ignite. Problem is worse the longer the top has been turned off. Once gas gets to the ignitor, it lights...
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Jul 15, 2010 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
When the larger burner on the right is on high is melts the plastic control nobs. How do I fix it? Thanks Jim
These burners are not supposed to be operated uncovered. If indeed the burner is covered and it is still causing the controls to burn than the resistance for that burner is failing and the burner should be replaced. Thank you, Dana
Oct 06, 2009 | Jenn-Air JED8430 Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Main burner will not turn off!
Burner control feel loose? Wheter it is or isnt that is probaly where your problem is..
Jan 20, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Wrong ignitor starts when burner is turned on.
Sounds like you have a bad ignitor on that burner.
Sep 25, 2007 | Jenn-Air JGC9430ADS Gas Cooktop
Maytag MEC5430 Electric Cooktop Logo
73 people viewed this question
Top Maytag Cooktops Experts
paulcarew
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
