Question about Gateway Computers & Internet
Why my computer wont come on - Gateway Computers & Internet
  • Gateway Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 15, 2013
Wont download on third computer
is cause your computer doesnt meet the requirements of the software
May 05, 2010 | Bling Software 123 Media Max Full Version...
My computer wont turn on
The power supply might be faulty. Look around on eBay and Best Buy, amongst other stores for one.
Mar 18, 2009 | Toshiba Satellite A100-S8111TD Notebook
Wont start 1996 tahoe 1500
SOUNDS LIKE YOU HAVE CONECTOR PROBLEM .CHECK ALL CONECTIONS AT COMPUTER. SPECIALLY POWER AND GROUND . CHECK FOR BURNT PINS AT COMPUTER . IF ALL GOOD YOU SHOLD REPLACE ECM.
Feb 01, 2009 | 1996 Chevrolet Tahoe
Ipod wont turn on and the computer wont recognize it
read the manual and the troubleshooting. that's how i fixed my 4th gen ipod.
Jan 17, 2009 | Apple iPod nano
Computer wont recognize psp?
try a different computer or different usb cable.
Jan 10, 2009 | Sony PlayStation Portable (PSP) Console
The orange light on my usb wont turn on. it was working just fine 2 days ago. after my last use i put it on top of my dresser and never touched it. Can someone please identify the problem when the orange...
Very good in checking if your computers' USB ports are working. Now that you know that your computer's USB ports are working, try your USB device on his computer and check if it'll work there. If it also doesn't work there, then it'll be your USB device that's not being read.
Jan 01, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Wont sign on to internet
Is the computer recognizing the connection to the network?  Does the home network use DHCP?  How do you have the network setup?  Does this connection work with a different computer?  Try pinging any other computer on the network, and try pinging a website.
Oct 16, 2007 | Compaq iPAQ Home Internet Appliance IA-2...
Computers & Internet Logo
14 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
