Question about Honeywell Heating & Cooling
Honeywell heater yellow light
P/N 034-04074-000 r1
2 Suggested Answers
SOURCE: Honeywell HZ517 Baseboard Heater
This troubleshooting approach may be sound, but you need a deep security star screwdriver to open the heater up. I have looked in specialty tool and electronics shops and no one has a screwdriver that gets in deep enough. You won't go anywhere without this screwdriver, so if anyone can suggest a source, that would be great.
Posted on Nov 30, 2005
HOW TO TROUBLESHOOT ROBERTSHAW GAS VALVE
check the pressure switch if voltage to both sides its ok then check the gas valve to see if voltage at brown and yellow wires
Oct 14, 2014 | Honeywell Robertshaw Grayson Gas Valve Lp...
Have electri heater. put in new honeywell thermastat programmable. did not hook up jumper wire like it said. now ac will not come on. if hook jumper wire, then both ac and heater comes on. whats the...
From end to end you have to put the red to red (24vac in), white to white (Furnace on wire), Black to common (24vac common), green to green (Fan On), yellow to yellow (AC On) and the jumper link back on. Also when you hook up the AC the two wires go, one on common (black) and the other on Yellow.
Looks like somehow you are picking up the AC & heater at the same time. If you need more info e-mail me at rspiak1@cogeco.ca
Jan 13, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell heater its old when I plug it in the wall it shows power on and that it is 59 degrees in the room when I push the button to set the temperature or even to time it to cut off and on...
there are auto reset limit or limits around the fan coil that can be removed/bypasses, However this is definately not safe to use as a home heater at that point, a day shop heater or garage type thing where you will be right with it and not asleep etc is ok, if you are a do it yourselfer or emergency fix till next day etc, but parts may be offy standard appliance in Sac Ca will do online parts but specific switch may be available as you have a Homeywell and not a chinesemodel i which case I wold say todss it its not worth repairingand in fact this one also may not be worth it actually
Jan 23, 2010 | Honeywell Electronic Programmable...
I removed the wires from the old thermostat before I realized that I needed to label them so that they could be placed in the proper place on the new thermostat.
Heating, red wire to R terminal and white wire to W terminal. Fan, green wire to G terminal. A/C, yellow wire to Y terminal, there may be a jumper from R1 to R2 terminals. If you have a blue wire it should go to C terminal.
Oct 18, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
New honeywell thermostat require yellow wire to install but my wiring does not have a yellow wire ,what should i do now?
you may have to pull in a new wire from the furnace to the thermostat. get hold of an electrician
Oct 15, 2009 | Honeywell Heating & Cooling
There is five wires yellow, green, red, white, the problem that we a facing is to connect these wire into the honeywell theromostat RTH3100C1002-0916
yellow is the cool wire, green is the fan wire, white is the heat wire, red is the power wire. these stats should have a 1 letter icon ,r for red on stat y for yellow and so on ,make sure that Rc and RH are jumpered and install batteris if needed
Sep 29, 2009 | Honeywell Electronic Programmable...
Just bought a home with a Honewell trol atemp universal mini zone
because it dosent have a duct sensor - should not be a problem
Sep 03, 2009 | Honeywell Electronic Programmable...
My heating/cooling blower (not the outside unit but the fan in the garage) does not turn off, even when my Honeywell TH8000 is set on automatic. What can I do to have the fan motor shut off?
try hard wiring your 24 volt that goes to the outside unit to the yellow wire coming back from your thermostat make sure the yellow wire is on the yellow terminal on the thermostat (honeywell) i have run into situations when this seemed to be the only thing that worked
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
421 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
