Question about Sharp Office Equipment & Supplies
What does the thermal fuse look like on copiersi have a konica minolta cspro 3000
  • Sharp Expert
  • 337 Answers
Which thermal fuse? the one(s) in the fuser? The fuses or the thermistors? There are thermal safety devices everywhere on that machine. Can you be a bit more specific?
Posted on Jan 30, 2013
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
  • 1297 Answers
SOURCE: minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
Posted on May 22, 2010
SOURCE: Minolta CSPRO EP 1080 isn't copying, shows only warning lights
I have a Minolta 1080 could be used for parts.
jim@solarsystemsintl.com
Posted on Sep 14, 2010
Cogz
  • 1326 Answers
SOURCE: Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Posted on Apr 28, 2011
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Exit tray broken for a Minolta CSPro EP4000
Legacy machine from Minolta now Konica Minolta. Try ebay? Or super glue. Try the web sit below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
My photocopying machine is sending me blank pages after photocopy
Minolta cspro ep 1031 My photocopying machine is sending me blank pages after photocopy
Jan 15, 2013 | Konica Minolta EP 2030 3000 Toner 2-410...
Minolta cspro 2010 error code c05
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
Not working
C0400, Exposure lamp failes to turn on. The lamp under the exposure glass is burnt out or the thermal fuse for the lamp has blown. Ohm out the lamp and fuse, replace as needed.
Apr 15, 2009 | Office Equipment & Supplies
Feb 06, 2009 | Minolta Di3010 Copier
Minolta cspro 2080 having black copies
chek the scaner lamp(upper lamp ) if its working during copy other ways u have to take up the lamp and check it by oem meter , u have to check also the thermal fuse for that lamp on the same unit. I hope that will solve ur problem ,if not high voltage unit above the drume is damaged.
Nov 24, 2008 | Minolta EP4000/5000 CS/PRO Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
