Question about Foxconn NF4UK8AA-8EKRS Motherboard
Boots on 1 sata drive but if i hook up second sata post but no windows
    Guru:
  • 433 Answers
Hi James Myers :
I make this video for you wish i help
Posted on Jan 15, 2013
Asus p5n-e sli will no longer stay on for more then a few seconds
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
Dec 15, 2012 | ASUS P5N-E SLI Motherboard
Can't see SATA drive
HI,
Let me first make sure I understand what configuration you have here. You've installed a new SATA drive and installed Vista on that SATA drive on this new motherboard. Then your trying to add an additional SATA drive to the motherboard that has data on it, but no OS. Is this correct? The problem your having is that when you put the drive with the new installation of vista on it, along with the old drive both being SATA, the old drive doesn't appear in vista but it does in Bios?:
Ok, if I'm correct in your config here, I would hook the new drive to SATA 1 and the older drive to SATA 2, and in bios boot to SATA 1. When you boot to vista, go my computer and right click to manage. Under manage go to disk management. It should see both drives and their you can format the second drive. If it doesn't see it, then try another SATA port.
Let me know, since I'm not confident on my assumptions.
Thanks
Mark
Mar 10, 2010 | EliteGroup ECS A780GM-A Motherboard - AMD...
SATA drive takes too long to boot up
Is the SATA drive connected to the first socket? Also, if the old IDE drive is not used, then disable their use in the bios - don't use the AUTO function.
Jan 31, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
Mobo will not power on if two sata drives are connected . The fans on system and cpu will not spin. System will power on and fans will spin if second hard drive is unplugged and system will post and boot...
good day sir, hi, its either your motherboard does not support 2 sata drives simultaneously or your motherboard sata port is bugged.
Choices:
1. get a bigger hard drive
2. use a PCI to SATA card for your extra SATA hard drive.
3. replace your motherboard.
Hope this may help.
Dec 17, 2009 | ASUS Computers & Internet
I've ms-7142 v:1 model mother board in this bios this not showing the sata option will u plz help me out of this...
go into the bois and make sure the sata raid or raid option is enabled, that should fix it
Oct 08, 2009 | MSI K8MM-V Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Sata DVD Ausus using K8V-MX
TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
note:
Jan 06, 2008 | ASUS K8V-MX Motherboard
Foxconn NF4UK8AA-8EKRS Motherboard Logo
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
