Question about Apple iPod shuffle MP3 Player
My ipod is freezing
I just got my new ipod shuffle for xmas and its already frozen 3 times but the last time it happened it wont work anymore the screen shows up and it will play music but my wheel doesnt work and the only way to change songs is to shake it
  • 342 Answers
With the cost of a new shuffle verses repair fees, I would recommend buying a new iPod.
Posted on Jun 28, 2009
2nd gen ipod shuffle non-responsive
Step 1:
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
Feb 19, 2013 | Apple iPod shuffle Second Gen. Silver (1...
My ipod wont shuffle anymore
How to Fix an iPod Shuffle That Won't Turn On
Things You'll Need:
* iPod Shuffle iPod USB cable Power adapter
The iPod Shuffle is the smallest member of Apple's line of MP3 players. During the device's lifetime, you may find that the iPod freezes or seems to not turn on anymore. Since the iPod Shuffle does not have a display attached to it, you cannot be notified of any device errors. However, there are several troubleshooting steps you can take to repair your iPod.
Instructions
Plug the iPod USB cable into the iPod Shuffle and then connect it to the power adapter to recharge the iPod's battery. The iPod Shuffle may not be turning on because its battery has fully drained.
Move the button on the back of the iPod Shuffle to the "off" position.
Wait five seconds with the iPod in "off" mode before switching the device back on. This process will reset the iPod Shuffle memory.
Connect the iPod Shuffle to your Mac or PC computer if it still will not turn on.
Open the iTunes program and sync your iPod with your computer. When you unplug your iPod from your computer, it should turn on normally again.
Hope it helped.
Have a nice day.
Feb 22, 2011 | Apple iPod touch
Hi my apple ipod shuffle 1g wont charge.. or play songs
You are supposed to transfer songs usin itunes....simple drag and drop doesnt work.... You can download itunes from www.apple.com\itunes
If you are already using itunes,perform a restore on the ipod using itunes...you will find restore option under the summary tab in itunes.
Sep 29, 2009 | Apple iPod shuffle MP3 Player
Frozen ipod
Here you go :) Please rate me on wether or not this article resolves your issue
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
May 06, 2009 | Apple iPod classic MP3 Player
While syncronizing my apple nano ipod with my pc my ipod was hanged
Do you mean the iPod was snagged with the USB cable? Is it frozen now? And have you already attempted to reset it? If not I have posted a step by step on resetting an ipod just in case you need the information still. I see that your issue was posted a while ago. Maybe its already resolved?
Jan 25, 2009 | Apple iPod nano
2nd Generation iPod Shuffle Wont Turn on and 3 orange lights sync
ALLOW IPOD TO RUN DOWN..BY LEAVING ON.THEN FULLY CHARGE.TURN ON AND IT SHOULD RESET ITSELF IF NOT LET ME KNOW.I WILL ADVISE FURTHER.RICHARDM69
Dec 04, 2008 | Apple iPod shuffle Second Gen. Silver (1...
IPod Shuffles 2nd Generation Keeps Freezing after 20 minutes
If a firmware upgrade does not resolve the issue, then that player is toast
Aug 16, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple ipod
press the centre circle button and the word 'menu' simultaniously and hold them down until the apple logo appears on the screen this shouldreset the ipod
Nov 11, 2007 | Apple iPod nano
Apple iPod Shuffle song loading
using the original CD that came with my iPod and magically fixed everything! Had to re-install iTunes
Oct 19, 2007 | Apple iPod shuffle MP3 Player
Apple iPod shuffle MP3 Player Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
