Palm Tungsten E2  Handheld
Problem for Palm Tungsten E2 (Multilingual) Handheld
Fails to stay turned-off
By GeofT on Jul 09, 2007
My Palm has recently started turning itself back on a few minutes after powering off. It then gets into an endless power-on, tim-off cyle. Consequently the battery discharges quickly. Maybe conincidence, but hot sync over WiFi no longer works. ANy thoughts greatly appreciated!!!
Comments:
Jul 12, 2007
- Thanks very much for suggestion. Unfortunately it doesn't seem to correct the problem. The next likely thing for my Palm is to be used to see how robust the technology is by dropping it 30 floors :-)
Jul 19, 2007
- I did vid the screen and noted that that when it came back on again there was an alert (flashing shriek mark). Apparently it was trying to sync versamail - which is not configured. De-configuring auto update for versamail has fixed problem. So many thanks for all your help - problem solved :-)
Best Solution
posted on Dec 10, 2007
Helpful)
Frano12
Rank: Apprentice
Rating: 74%, 10 votes
Resetting palm to default mode should fix this, there is a program installed that is running in background mode that is responsible for this, your job is to identify this program and remove it from memory and your backup or archive directory on your pc. good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 09, 2007
Somewhat Helpful)
TomShpak
Rank: Guru
Rating: 85%, 230 votes
Hey there
I Think it has to do with the hot sync not working anymore, the WiFi is looking for sync so it turns on the pda, in order to avoid it just enter in your setings for automatic networks search or somthing like this and disable it
Good day
Comments:
Jul 15, 2007
- put it on Youtube i'd like to watch it
Was this helpful?
Yes
No
Popular Solutions for Palm Tungsten E2 Handheld
Questions and Unsolved Problems for Palm Tungsten E2 Handheld
Do you recommend Palm Tungsten E2 (Multilingual) Handheld?
Answer
Answer
This message comes up "conduit manger is busy?" when I am trying to hot sync. how do I fix...
Answer
i can't access my list of pdf files. I need to delete some files but the application jumps from the... (More)
Answer
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the... (More)
Answer
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDAs Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
