My lg wm1814cw won't come on but outlet have power
  • Washing Mach... Master
  • 17,130 Answers
Possible that the power supply to the program controller unit has failed or that the program controller panel by itself has failed.
Remove the panel after disconnection of power and check for input power to the panel, check for fuse., if the fuse blows up again the board can have shorts within and will need a replacement.
Posted on Jan 15, 2013
5 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Posted on Jul 12, 2009
CMV9
  • 594 Answers
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Posted on Apr 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
Posted on May 20, 2010
inokumum
  • 10 Answers
SOURCE: My LG washer won't power up
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Posted on Feb 09, 2012
No power at all
Possible that the main controller has failed if there is power till within the power supply unit of the controller.
You need to probe into the power supply unit to confirm for a fuse failure, a link failure on the Low tension circuit, a failure to provide power to the controller.
Dec 31, 2012 | LG WM1814CW Front Load Washer
Washer won't drain. How do I get to the pump
first chec in the pump ,, a coin may obturate..
Nov 05, 2012 | LG WM1814CW Front Load Washer
Washer wont spin and makes a clicking noise
I have a LG front load and it won't spin or drain... Can u please help me
Jul 01, 2012 | LG WM1814CW Front Load Washer
Feb 09, 2012 | LG Washing Machines
Washer won't spin. LE Error
'LE' stands for 'Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | LG WM1814CW Front Load Washer
LG WM1814CW washer - doesn't fill with water. Hear a hum when it should be filling with water, but no water and no error codes. I am guessing Valves (F160 and F170). Any thoughts?
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 08, 2011 | LG WM1814CW Front Load Washer
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
#1The fabric softener dispenser won't drain.
Make sure the dispenser is clean and free of debris inside the containers. You may have to take the dispenser apart and clean it out in the sink.
Jun 23, 2011 | LG WM1814CW Front Load Washer
My drum light is on and won't go off.
If the water still operates then it is the panel switch. If the washer does not operate, then it is the door switch.
Jun 04, 2011 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
