Question about Opella 2-3/8" Push-Push Drain Assembly OPELLA 90135.110
Missing part. Missing out of the box is the under waste gasket (#3). How can I get on ASAP
Engine misses when going up incline until I let off gas
Missing under load can be caused by a number of different things including:
a bad sparkplug
bad ignition wires
if your car is old enough,
bad distributor cap
Also, it's possible it's missing all the time, and you only notice it under load. If so, then add
bad valve
bad piston or rings
blown head gasket
Apr 18, 2015 | Cars & Trucks
Oil leaked out from the oil cap and the engine cover has a missing screw
Oil may have been over filled , if not a faulty cap , the missing screw wouldnt cause a leak from the cap , check no oil leakage around missing screw (may need to clean area first) this could cause rocker cover gasket not being compressed properly
Feb 10, 2013 | Holden Barina Cars & Trucks
Is there an override button is not clearing garbage
If disposal is not running, then push red reset button located bottom of disposal.
If disposal is clogged, Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 19, 2012 | Badger 1 Insinkerator 76039h 1/3 Hp Feed...
Subaru missing after head gasket replaced
do a compression test on each cylinder to find out which is leaking
Aug 15, 2012 | Subaru Forester Cars & Trucks
Xerox phaser 8560 printer is saying waste tray missing but it is not
Are you sure you are looking at the waste tray, and not the paper tray? Here is a link to the user manual for the printer. Information about the waste tray is on page 194. This should give you an idea of were it is located.
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf
hope this helps
Feb 22, 2012 | Xerox Phaser 8560/YN Printer
Audi missing at idle, engine smoke, and vacuum leak
audi oil leaks are usually valve cover gaskets. oil run off causes smoke on exhaust downpipes.while vacuum hoses do tend to dry rot with time it may also be the secondary air injection pump (if cold ) or waste gate for turbo.try to use a long hose,put one end on your ear use the other to locate sound. extending mirror and light may help too. missing at idle could mean time for tune up or coil pack failing. good luck
Mar 23, 2010 | 2004 Audi A4
My head gaskit was burn and I most change it.
DO YOU MEAN YOUR HEAD GASKET HAS BURNT OR BLOWN AND LETTING WATER INTO THE ENGINE.
Or has the gasket blown and engine missing on a cylinder,, and if so does the engine overheat/loosing water/running rough/white smoke out the exhaust pipe when you start up/and how long has it been diong it..
Must know the answers to all of the above so we can give you the correct answers...ASAP.. RON
Nov 22, 2009 | 1998 Chevrolet Cavalier
Missing field wire. still charging need a wiring diagram please help
WHAT FIELD WIRE IS MISSING.
Let me know A.S.A.P as earth wires are 2 from battery 1 goes to Engine block and the other one goes from engine to any bolt or nut under bonnet on either firewall or mudgaurd and from there you might have 1 to the radiator.
Oct 11, 2009 | 1986 Ford F 250
I can hear a major leak on the passenger side of the exhaust but can't locate it
well if you can hear it its there wait until the vehicle is cool preferably overnight then with your hand carefully feel along the pipe top included fro holes etc. and look over the main connection points to ensure proper fit and no missing bolts due to deterioration as well as the gasket again feel for the missing or pinhole missing gasket along the topside as well as a closer look then look at the header and catalytic converter connections could even be under the heat guard { shield} would love to know if you find something
Sep 06, 2009 | 2002 Ford Mustang
Opella 2-3/8" Push-Push Drain Assembly OPELLA 90135.110 Logo
78 people viewed this question
Top Opella Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you an Opella Plumbing Expert? Answer questions, earn points and help others
