Question about Thermaltake Intel LGA775 1/2U Solution (WMM130110) Motherboard
Ventilator of the microprocessor
Hello the ventilator of the microprocessor makes noise because it goes always very fast (4600 rpm) to resolve it? thanks
  • 624 Answers
Most modern motherboards include temperature sensors that can speed up or slow down the CPU fan depending on how hot the processor is. If its noisier than it was originally it could be: -inefficient cooling caused by dust accumulating in the heatsink under the fan. -could be heat buildup in the case itself causing the processor to run hot. -could just be noisier because the bearing in the CPU fan is wearing out. -Make sure the CPU fan power cable is plugged into the proper socket. If it?s not the motherboard cannot control the speed. Let us know if you have any other questions.
Posted on Jul 10, 2007
6ya staff
SOURCE:
What are the torque specs for the main caps?
Engines & Power (more) Four-Wheel Drive Trims
spacer.gif Laredo 4WD TSi 4WD Limited 4WD Orvis 4WD Standard Engine 4.0L 185 hp I6 4.0L 185 hp I6 4.0L 185 hp I6 4.0L 185 hp I6 Horsepower 185 @ 4600 RPM 185 @ 4600 RPM 185 @ 4600 RPM 185 @ 4600 RPM Torque (lb-ft) 220 @ 2400 RPM 220 @ 2400 RPM 220 @ 2400 RPM 220 @ 2400 RPM Rear-Wheel Drive Trims
spacer.gif Laredo 2WD TSi 2WD Limited 2WD Standard Engine 4.0L 185 hp I6 4.0L 185 hp I6 4.0L 185 hp I6 Horsepower 185 @ 4600 RPM 185 @ 4600 RPM 185 @ 4600 RPM Torque (lb-ft) 220 @ 2400 RPM 220 @ 2400 RPM 220 @ 2400 RPM
Nov 12, 2010 | 1997 Jeep Grand Cherokee
Need the specs for HP DV7 Laptop motherboard #486542-001. Most interested in what AMD Turion X2 cpu's this motherboard supports
Microprocessor 2.26 GHz Intel Core 2 Duo Processor P8400
Microprocessor Cache3 MB L2 Cache
Memory 4096 MB
Memory Max8192MB
Hard Drive 320 GB (5400 rpm)
Take care.
Jun 01, 2010 | Computers & Internet
Firewire PCI into Dell 4600
First of all, I use Pinnacle all the time for Video editing, and it is the best for this application. You will need to install a fire wire card in your system, they are available at any Best Buy or online. I use tigerdirect.com for my online purchases. they are fast and they have good prices. Once you have all that hooked up your video editing will be a breeze.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 23, 2009 | E-Machines GM5260 (1009304) PC Desktop
Noise in the gear box of a 2004 suzuki rm 85 2 stroke
Sounds like the cam chain needs to be adjusted, it's normal for bigger bikes check a manual for the procedure for your bike. it normally take about five minutes. hope this helps
Jun 27, 2009 | 2004 Suzuki RM 125
Hp 4600 noise problem
when power on the main board do initial devices:
1) the cartridge include toner unit and photo drum unit
2) fuser unit and all paper road include motors and sensors through the paper road.
the noise at power on you may check:
1) the toner unit that maybe over life cycle to mak much more obstruction, you may take out the cartridge and turn the gears if felling very hard so need to change the cartridge.
2) the toner unit gears damage a little that could make noise, you may check all gears on the cartridge. attention other side drive gears.
3) check the fuser unit gears do same thing above.
hope you fix it and feedback the result thanks
May 06, 2009 | HP LaserJet 4600dn Color Printer
Power supply and CPU fans spin fast
There may be no problem here. Has it always done this? Usually when executing some major tasks the CPU gets hotter and sends a signal that it requires the fans to work harder to keep from overheating. This may be normal.
hope this helps!
Aug 14, 2008 | HP Pavilion d4100y (PX181AV) PC Desktop
Open Questions:
See all Thermaltake Intel LGA775 1/2U Solution (WMM130110) Questions
Thermaltake Intel LGA775 1/2U Solution (WMM130110) Motherboard Logo
Top Thermaltake Computers & Internet Experts
Lawrence Oravetz
jamulder513
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
