Question about Dishwashers
Liberty soft close drawer slide jam
Drawer slide has jammed closed. Cannot open drawer more than 1 inch
reg501
  • 413 Answers
SOURCE: The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
Posted on Jun 01, 2008
SOURCE: constant paper jam
I had the same problem but was using a replacement toner cartridge made by PRINK. When I purchased a true Samung toner cartridge the problem went away.
Also, try changing the paper for a different make, some are "stiffer" than others and cause a jam.
Posted on Jul 29, 2008
killer_clown
  • 86 Answers
SOURCE: cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Posted on Oct 24, 2008
SOURCE: bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Posted on Nov 25, 2008
jay_win2002
  • 16 Answers
SOURCE: dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' jay_win2002@yahoo.com .
Posted on Jan 30, 2009
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
Sony camcorder drawer has jammed open
problem solved by friend who found a by-pass socket for charger on camera which charged battery enough to close tape drawer. Thank you
Jan 07, 2010 | Sony Video Cameras
Keep getting message rear draw open
If you pull the fuser out, look at the bottom of the sliding mechanism for a bent metal tab that actuates a switch when you close the rear drawer.
They get bent pretty easily.
Jan 22, 2009 | Kyocera FS-3900DN Laser Printer
Cannot close middle front drawer
you have to take off the left side cover and you see 2 gears close to the middle of printer, those have to be turned to release the clutch for the drawer. The drawer should now slide in.
Nov 18, 2008 | HP Color LaserJet 4500n Printer
Cdr20 drawer is jammed ERROR message
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Dishwashers Logo
Top Dishwashers Experts
