Question about Kenmore Sewing Machines
Where can I get a power cord for Kenmore Sewing Machine Model 358 120145
  • Kenmore Master
  • 7,365 Answers
Check with these sites, you'll have to call them or email them
sewvacdoctor.com
a1sewingmachines.com
Posted on Jan 15, 2013
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
Just got a kenmore sewing machine model #158-900. It is powered with your knee. When I plug in it automatically starts running and can't shut it off. Any suggestions would be appreciated
On old machines there will be two power cords coming from the machine, one for the motor and one for the light. They in turn plug into a receptacle block with outlets marked motor and light. It sounds like your motor is plugged into the light receptacle. If you can find the block try rearranging the plugs.
Bob
Sep 15, 2017 | Kenmore Sewing Machines
What kind of power cord do I need for a Singer Sewing Machine Scholastic Model 6704?
go to e bay and put this model in and ask for a power cord and see what it shows then look at yours for a spot for it good luck
Jun 05, 2016 | Singer Sewing Machines
Where can I purchase a used Sewing Machine Foot Control Pedal & Cord
Try eBay or a sewing machine repair service.
Search the internet, inputting:
Manufacturer + Model + "parts"
Aug 16, 2014 | Kenmore Sewing Machines
I have a kenmore sewing machine 158.19800 I need a manual , power cord and petal where can I find them ?
try these sites, you'll have to email them or call them
sewvacdoctor.com
or try ebay
Jul 15, 2014 | Kenmore 15218 Mechanical Sewing Machine
Missing power cord
Buy a new one, bring your machine to a sewing machine service center in order to make sure they have the correct cord.
Mar 06, 2014 | Kenmore Sewing Machines
Foot pedal and power cord
also try sewvacdoctor.com for parts
Jul 12, 2013 | Kenmore 15218 Mechanical Sewing Machine
Why is the motor of my sears kenmore sewing machine model 385.12714 running really slow? The machine has not been used for at least a year or two. We oiled it. It is sewing, but at a snail's pace.
it could be different things
have you checked to make sure the plug is correctly in the machine
one time I was sewing on my necchi electronic machine & it for some reason was going slow like you mentioned & so I started checking different thing & found the cord to the foot pedal was laying in side the foot pedal & it couldn't go any faster untill I moved the cord out of the way
it could also be the motor
& also the power cord & foot pedal
it's possible it needs to be serviced since it's been sitting up so long & since it's sewing at a snails pace
Sep 11, 2011 | Kenmore Sewing Machines
I have lost my power cord to my Janome model 5024 sewing machine
There are several location where you can purchase a power cord for you machine, Here is an online source, Hope this helps
http://sewingpartsonline.com/power-cord-kenmore-385-12916-sewing-machine.aspx
Aug 16, 2009 | Janome Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
